Dan Clark Audio Stealth Review, Interview, Measurements
Sep 1, 2022 at 10:26 AM Post #4,891 of 6,136
The sub par sound is due to quality of signal chain, power supply and transport. Solid state is preferred since tubes will just ruin the transparency that the Stealth can deliver.
If you have great soucre like Innuos pheonix then you dont need conditioning. Just clean amp and dac.
Many headphones can sound harsh with source like usb since very few dacs have built in reclockers.
Sep 1, 2022 at 10:37 AM Post #4,892 of 6,136
Innous phoenix is not a 'source' and it only uses 2x lt3045 voltage regulators. I use 100x lt3045s and still scale greatly optimizing the zen stream on the upstream. So the innous Phoenix is not a bullet proof solution.
Sep 1, 2022 at 11:12 AM Post #4,895 of 6,136
In most cases SS will be better. Because of the low impedance. However something like a Woo WA33 or WA5le have plenty of power. I’m sure there are plenty more, I only have experience with those and the Stealth.
Overspecced power and output transformers that have proper impedance damping factor provide ample current for hard to drive planars in general
Sep 1, 2022 at 11:32 AM Post #4,896 of 6,136
UAC2 protocol over USB uses receiver (DAC) clock to tell the source to send the next packet faster or slower, effectively making the DAC clock the one that controls the data rate.
Sep 1, 2022 at 11:34 AM Post #4,897 of 6,136
Absolutely. The two Woo amps I mentioned are transformer coupled so work well. OTL amps probably not. Of course nothing wrong with trying it.
Sep 1, 2022 at 2:05 PM Post #4,898 of 6,136
Any DAC, especially a $200+ DAC that cannot deal with simple USB jitter / noise and produces audible artefacts, does not belong to this century, because the designer of that particular DAC was not competent and s/he failed to implement a very basic part of asolved problem in digital audio.
Let's think about this: We have mobile phones that can communicate with a base station through air, behind multiple levels of walls, hunderd meters away, signal being constantly scattered everytime it hits an obstacle, which are mostly moving and emitting signals themselves, both our mobile phones and base station receiving tens of variations of the same signal due to the delays, irregular phase shifts, amolitude changes etc., and this is happening for hunderds of other communication channels (people) between mobile phones and base stations. And still, we are able to send and receive megabytes of data in seconds. Yes, there's error correction, yes there is coding, yes there's time and frequency multiplexing, yes there is modulation, yes there's many other forms of signal processing applied to do this, but what I want to say is: These little devices with their small chips can cope with much more complex cases of communication issues at such a low price (I am not talking about latest Apple or Samsung). If a DAC, which is connected with a 1m cable (not air) without any obstacles on the way is not able to cope with a much much simpler problem in this century and we need devices that cost multiple thousand $/€ to fix them, there's something definitely wrong there. Both with the DAC (because it was not properly designed), and with that "fixer", as it is not a problem that needs multiple thousands to fix.
Sep 1, 2022 at 2:26 PM Post #4,899 of 6,136
The DAC clock comes from XMOS USB chip (not from the source) in UAC2 / Async unless that DAC has a VXCO/OXCO crystal oscillators are included for reclocking. The SPDIF clocks are derived from the source wordclock unless once again that DAC has VXCO/OXCO crystal oscillators are included
Sep 1, 2022 at 2:31 PM Post #4,900 of 6,136
While they won't ever give an accurate representation of the recording, they do give a more engaging presentation for most recordings IMO
Sep 1, 2022 at 10:02 PM Post #4,901 of 6,136
Don’t let 801 get going again about signal chains.
The power potential of the amplifier is absolutely at play for the value and experience provided by the DCA stealth HP. In general the more power the merrier, to a point.
I have run my set off DCA stealth on easily 25 different rigs, from dragonfly to Wa33, from topping A90, monolith, Yggy, Wells audio and XI audio and now Enleum amp 23R and M17.
To at least sidestep the insanity of constantly delving deeper and deeper into the cabling I can say that reproducibly, all interconnects remaining static, the increase in power supplied to the DCA stealth amplification yields more and more SS size, bass extension/weight/presence, musical separation and all the rest.
When people say “Hard to drive” the more accurate statement is that they will not be the limiting factor in your chain. Either quality of reproduction in DAC, or quantity of clean power to amplify them definitely will be.
Sep 2, 2022 at 8:29 PM Post #4,903 of 6,136
So is there a DAP that can sufficiently drive the Stealth? Read DX300 Max and the M17 would be contenders but.... better than Chord H2?
Sep 3, 2022 at 5:14 AM Post #4,905 of 6,136
Do you need a DAP or are you asking if you can find a DAP than can give better results than H2?
