brianfromspace
Never heard it, will check tonite.Has anyone here experienced driver crackles with the expanse when you put them on your head or adjust them slightly while they are already on your head?
Yup, same here. If you push the cups slightly toward your head I can hear driver crackling.Its air moving the driver. The stealth does the same thing if you try pushing the headphones against your ear. Maybe the Expanse is more sensitive to it when you adjust the fit but it shouldn't be happening when you're listening to music unless youre getting up and dancing with an extra long cable making the headphone shift around.
Never had it on the Expanse but I know this from my old Audeze LCD-2C.Has anyone here experienced driver crackles with the expanse when you put them on your head or adjust them slightly while they are already on your head?
They are very comfortable for long listening sessions.I’m considering getting the stealth to use as my daily use home working headphone. Comfort is very important. I listen to all genres from classical to electronic and metal. I’m planning to use the fiio m17 in dc mode and the hugo 2. Could the stealth work for me?
M17 DC power can still sound underwhelming due to the distortion level of the M17.I’m considering getting the stealth to use as my daily use home working headphone. Comfort is very important. I listen to all genres from classical to electronic and metal. I’m planning to use the fiio m17 in dc mode and the hugo 2. Could the stealth work for me?
Cool thanks for the information. They do look very comfortable. I may need to sell some other audio gear to make up some fundsThey are very comfortable for long listening sessions.
I listen to all genres too. I’m mainly classical, acoustic, and rock. EDM is the weakest on the Stealth, but if you eq the bass up a bit, the Stealths respond very nicely.
You can run them straight off the Hugo 2 no problem by the way.
you can but in truth they need more power to shineThey are very comfortable for long listening sessions.
I'd say they scale with better sources more than they need more power.you can but in truth they need more power to shine
