Now we need
nmatheis to check in after he tries it.
I revisited the Ultrasone PRO2500 again.
I had toned it back to 3 x 1cm squares of 30D 1/10.
Two on either side right at the offset driver and
one at the top opposite that, all were on the mu-metal baffle plate but away from the edges about 8mm-sh. This also helps the pads stay a bit more snug ( less backing off ) with their fast-swap tab system.
It was a bit too tight sounding and even though clarity was great it was lacking some of the increased body that some of the other mods I have done managed to bring out.
So I decided to move all Sorb away from the driver.
I ended up with
only two 1cm squares directly across from the driver at the top of the metal baffle plate. BINGO. Things bulked up more with greater bass extension and overall improvement.
No longer have that feeling of "something is off "
I gave some of this stuff to my brother to try out on his Ultrasone PRO2900 so will hassle him until he tries it, and hopefully he can see the difference, as he is new to this, but each time they are out he gets to check out a ridiculous amount here so is likely now better able to distinguish before and after, and at least describe what he is hearing.
I'm sure there was another thing I did up ( if not more ), but can't recall right now what that was.
Oh yes the Fostex T50RP special mod I had. ( but there are more I forget what )
It's not pretty but nobody sees it.
Plus it is directly on top of the Dynamat extreme. Dynamat adds very little to my mind, I might as well not use it except for sealing drivers to baffles.
Effects noted at link >
http://www.head-fi.org/t/618659/fostex-t50rp-incremental-mods-and-measurements/1935#post_12010490
This particular case is an example of more is better
added an extra row:
