Marshmallow85
By the way whoever has Dali io6 please put on Crystal Method's "The Raze" or "Holy Arp"and tell me if you feel like the bass is too flat for ya )) it's a pure joy!
Oh shame, hopefully you will find a better pair soon. I just checked, no hissing sound in my Dali. Was it with ANC on or Off? Or maybe on transparency setting?
I see. I would recommend getting a new pair, but if you find them uncomfortable then better return. I actually returned my first pair due to battery playing up with percentage values. Second paid is flawless though the clamping force feels somehow lighter.There was a hissing noise with ANC on but that was to be expected. The static noise appeared when ANC was off. Sounded like electronic interference. My search continues. Maybe the Fiio EH3NC?
Yeah I've opted to return them. Know what you mean about battery percentage values playing up. Mine had the same issue. They would inexplicably go from 50% to 60% after 5 mins of usage and 5 mins of being turned off. Weird. Didn't really care about that though.I see. I would recommend getting a new pair, but if you find them uncomfortable then better return. I actually returned my first pair due to battery playing up with percentage values. Second paid is flawless though the clamping force feels somehow lighter.
Sent my IO6s back (along with the PX7s). The IO6s were uncomfortable due to their shallow / soft / round earpads. Also, when not playing sound there was static noise.
Spotted on ecoustics: 'However, in forgoing ANC, the IO-4 is able to double its battery life to an incredible 60-hours per charge'
I was wondering whether this now means that if permanently keeping ANC disabled, the IO-6 also should be capable of those '60-hours per charge'?
No, because the chip used for ANC functionality is still being used for audio and so it doesn't matter
Hi WDitters,I'm definitely in love here .. After a good number of years where I spent a lot of my mobile life with Bowers PX, Bose QC20/25, Sony XM2 and XM3, and recently the PX7, I now have completely fallen for the Dali IO-6 ... I never really seemed to find my sweet spot when it came to wireless cans, especially because of the fact that at home I kept being spoiled by my MrSpeakers Ether C Flow headphones and iFi Micro BL headamp ...
But the Dali IO-6 for me definitely are the first ones to actually show a relaxed form of sheer musicality and a nice slightly neutral sound signature that reminds me of my higher end cans, the MrSpeakers Ether C Flow.... Of course, in comparison the Dali IO6 are a bit more bass-heavy, less detail and clarity and a (much) smaller soundstage ... But they are definitely the most musical pair of wireless ANC headphones that I have come across .... Absolute keepers ... (And that without even having properly been broken-in yet with pink/brown/white noise loops)
Interesting .. Because Dali's own whitepaper at http://www.sound-pixel.com/files/product_pdf/DALI IO whitepaper_EN 10-09-2019_0.pdf says: "ANC OFF: All noise cancellation functions are switched off. IO-6 battery life is significantly improved when ANC is switched off" at the bottom of page 10 ...
I have had our Product Manager (headphones) reply to your questions. Here's his replies in the same order.
- At the moment we have not planned an app as we are unsure of which value it would add, and there are not many settings were it would make sense to change it.
- On the IO-6 the ANC chip is also the amplifier and it almost uses the same energy regardless if ANC is ON or OFF. So Battery life of IO-6 is always around 30 hrs.
- We considered it but after doing a user study decided not to do this as most people won’t use it and prefer the normal way of pairing BT devices ( what they are used to)
- The IO will remember up to four devices
- No, the IO’s only support one BT connection at the time.
- The IO have Class 1 support
- It is a Qualcomm solution in order to run aptX, the exact chipset details we cannot disclose.
- The D/A convertion is handled by the front-end BT chip. On USB it’ll support 32kHz, 44.1kHz, 48kHz, 96kHz.
- The 3,5mm cable is just a straign stereo cable. In passive mode ( OFF or with empty battery) play back will work, just as any passive headphone.
- The Multi-button( logo on the right hand cup) controls Play/Pause, skip track, take call, and it held down it’ll activate Siri/ google assistant.
- They are available at Richer Sounds
