DAC frequency response question
Dec 5, 2022 at 10:30 AM Post #106 of 134
IMPARTIAL - means that I have no intention of throwing away my hard-earned money, just to feed my illusion.
You still did not say if you do this testing of a new component by a blind comparison with the old component. If you don't then the results are unreliable. The most sincere intention to be impartial can and will not solve this. Nobody in the world can just switch off all his known and unknown, conscious and unconscious biasses.
Dec 5, 2022 at 11:10 AM Post #107 of 134
OK, everything I've pointed out here is nonsense. You're right.
I will continue on my way, and let your judgment guide you
Have a nice day
Dec 5, 2022 at 1:25 PM Post #108 of 134
I'll try one more time
I know my songs, the musical performances I listen to every day, every tone, its texture, spatial representation, it's always the same.
When I connect a new component, it can have a negative effect on some segments, or on everything. It has never happened to me that nothing has changed, and if it has a positive effect, I can detect exactly where and how.
These changes are hardly visible if you have simple devices, they can but if you change the headphones or amplifier or DAC, but not for other more subtle accessories that greatly affect the sound
So, why would I allow myself to buy something that will slow down my system, just because it's a big brand and expensive and everyone praises it, because it doesn't work positively in my system.
Yes, that's why I don't need a blind test, but wide open senses
Dec 5, 2022 at 1:34 PM Post #109 of 134
One more thing.
Many have closed the door to a better perception of music, due to the prejudice that prevails at Sound Science, which is that the cables you get with the devices are quite enough. Once you step with a better cable, you will understand.
Dec 5, 2022 at 4:16 PM Post #110 of 134
Dec 5, 2022 at 6:21 PM Post #112 of 134
The difference between us is that I'm trying to help,and you , to keep other in the dark. That's where you can put yourself in an important position. Your followers are just a flock of sheep with clouded minds.
I agree that you have stated a lot of nonsense
Dec 5, 2022 at 6:26 PM Post #113 of 134
How much longer do we have to put up with this castle? This is the second time he’s doubled down to this point. Last time he went away when the admins got involved. Should I just report all his posts?
Dec 5, 2022 at 6:31 PM Post #114 of 134
This is a thread about DACs. You say that they all do the same job and there is no audible difference between them, provided that they are all correct.
You really deserve to be the leader of your little sect
Dec 5, 2022 at 6:43 PM Post #115 of 134
I would also ask the administrators to disable my further participation, because it is difficult for me to ignore this thread , and even to delete all my posts.
Thank you in advance
Dec 6, 2022 at 11:56 PM Post #117 of 134
Hooray for Europe!
Dec 7, 2022 at 1:04 AM Post #119 of 134
Hooray for down under in the top right!
The phone doesn’t show that. I apologize for mistaking you for a foreigner.
Dec 7, 2022 at 6:06 AM Post #120 of 134
No hooray to your phone. Isn't your secret lab in the US? To you both us Europeans and those Australians down under should be foreigners.
