cravenz
- Aug 4, 2009
morning/afternoon bump.
Yup, that is good enough for me, but the problem is, to captialise on that, it effectively rules out the DAC19DF model due to it being 16/48.
I suppose you can ask KingWa for DAC-19DF USB upgrade to newest Tenor 24/96 implementation... DF1704 allows 24/96.
Heck, he spoiled me to the extent that every piece of gear I ordered from him was customized in some way.
Hello, I am thinking of buying a DAC (without amplifier) to feed my headphone amp. It'd be great if it had USB, digit and RCA analog inputs, and stereo RCA output.
Is there any good one under 150 USD?
Thanks!
I think the Musiland Monitor 02 does all that
Can I use it without a computer? I would use it sometimes connected to CD player.
Gigawork
That's one that is supposed to be decent if you can put a case together. I'm not very good with the other models in that price range though so hopefully someone will be able to chime in, but the Gigawork one got pretty good reviews from my local forum.
Thanks!
Does it work without PC?
Before I go through that forum, what do you think about ZERO? http://cgi.ebay.com/Zero-09-24BIT-192-DAC-HEAD-AMP-USB-OPA2604-NEW-VERSION-/320563401419?cmd=ViewItem&pt=LH_DefaultDomain_0&hash=item4aa31152cb#ht_7599wt_1137
Any DAC can be used by digital sources its their very purpose.
You will find mostly spdif input and toslink.
