tracyca
- Nov 5, 2012
I love my Duet amp, with se 846 explosive! My pico slim is having some quiet time now.
I love my Duet amp, with se 846 explosive! My pico slim is having some quiet time now.![]()
I agree with this. The noise floor is very low. It isn't as low as the Vorzüge amps, but low enough that it will never ever get in the way of good music. The DUET is an amazing amazing amp. I think it will become a huge hit.
The JH13 is pretty much my king of imaging but with the solo/duet, the F111 gives up very little to the JH13 in terms of space and defining the images with in it. I can't remember ever being this impressed with a piece of portable kit.
Shigzeo,
How would you characterize the Duet vs the Mark III B+ in balanced mode with sensitive IEMS (mine are UE 11 Pros)? I am leaning towards the ALO as my AK120 B Mod is a little lean in the bass (line out) and the warmer signature plus bass "boost" is mighty tempting. Soundstage width and depth is also important to me. Is the ALO unit much noisier or just slightly noisier (liveable)? How about dynamics and slam? Would appreciate any input on this as I have yet to find any direct impressions sharing the differences between the two.
Thanks, Ole.
Shotgunshane,
Noticed in your profile that you own the AK240. How does the Duet marry with this unit? I own the AK 120 B Mod and can't decide between the Duet or the Mark III B. Any thoughts on this would be greatly appreciated. Is the Duet better in a single-ended mode using the Solo DAC or do you like it just as much balanced with the AK?
Thanks, Ole.
Any one have tried the Duet pair with the DX90? Any thoughts?
I can give some input on that. Duet soundstage and separation, as shane mentioned, is pretty hard to beat. The width is noticably wider and overall sound on the duet is more neutral and detailed than just the DX90 alone. Duet also gives a really nice sense of air and space.
The DX90 on the other hand (fw 2.0.0), is overall more forward sounding and for me a more engaging and fun sound with a little more bass impact.
I did end up selling the Duet to fund a desktop rig and stick with just the DX90 for portable use since when im on the go, i dont need all the last little bit of detail the Duet pumps out, and I do enjoy the more engaging sound from the DX90 for on the go use. Plus without the stack the DX90 is pocketable.
The Duet has a very nice dark background with iems with minimal hissing, but DX90's background is even cleaner.
Overall if you're looking for an amp to pair with the DX90, the clean sabre DAC of the DX90 + the very clean sound of the Duet makes for really quite an impressive combo. I just personally went with the more portable and purely for music enjoyment route.
Thanks for that detailed inputs! Have you tried it with FW 2.05? Im using the new one which i find more neutral. Any thoughts? Thanks!
Unfortunately I sold my Duet before 2.0.5 was released. Sorry![]()
I'm unsure if you've seen this but here is Mike's impressions and comparisons with the Duet (he uses the a AK240 + Duet combo for his Audeze LCD-XC)
"I like it better than the ALO Rx MK3B+. The ALO is more powerful with a stronger bass impact and more forward mids. Usually stronger bass is my thing but in this comparison, I prefer the Duet. It's more spacious, cleaner sound, blacker background, and a bit more laid back.
It also sounds like a fresh breath of air compared to the Intruder with its usual RSA weighty lows-sound. The comparison is also similar to the RX. The Duet is cleaner, more spacious, blacker background, a bit more laid back.
This puts the Duet as being more spacious than any of the current ALO or RSA portable amp I know. The only thing that's wider is Fostex's new HP-V1 but the Fostex is a bit weak on bass impact so I don't really enjoy the tradeoff.
If you've listened to the Vorzuge Pure, the Duet is a bit to that direction except that the Duet is wider, has a better depth, blacker background. The Vorzuge is a bit smoother though."
You'll find this in the comments section in his LCD-XC review. Also, Shigzeo, Nathan, has his reviews of the Duet and the RX in his signature just in case you haven't read them!!
Good luck!! (get the duet)
Hey Ole,
I no longer have the Duet. I sold it and the solo to fund the AK240. And I have no plans to amp the AK240. I've learned that if I cannot easily pocket my portables, my usage wanes.
That being said, the Duet is the most spacious amp I've heard. The Ak240 by itself is also very spacious but the Duet's left and right separation is quite amazing and when you add that to its utterly black background, it's pretty awesome. The F111 had great synergy with it.
I ran the Duet almost exclusively with the solo -db. The two units were connected balanced for most of my usage, even when using single ended iems.
If you are an iem user, I'd probably stay away from the ALO unit. Everyone I know with it says there is noise and/or hiss with many of their iems (doesn't apply to headphones).
Sorry I couldn't be of more value on that question but Shiqzeo might be able to help if he still has the Duet, as he is currently borrowing Anakchan's AK240.
