CX, EX, K, S, Oladra, Antipodes, Owners Unite
Dec 19, 2022 at 11:29 AM Post #2,161 of 2,691
EX Operating Temperature now displayed via AMS v4.2
Can anyone share the operating temperature and CPU usage of their EX?
My CX and EX are running at very low CPU usage but according to the temperature readings, the EX runs significantly hotter than the CX -
86 degrees F [CX] vs. >120 degrees F [EX].
With CX and EX sitting side by side and unobstructed, touching the fairly cool outer enclosure of either unit does not indicate [to me] the disparity between temperature readings.
If I could get a few user data points, maybe I can determine whether this is typical or not. Still awaiting comment from Mark Cole.
CX Screen
EX Screen
Thank you.
Rich
Dec 19, 2022 at 2:23 PM Post #2,162 of 2,691
Dec 19, 2022 at 2:32 PM Post #2,163 of 2,691
My EX running naa:
Thanks for the screen shot...
My EX dynamically reads between 45C to 51C. I must have captured a momentary high of 53C.
Looks like we're in the same ballpark. :)
Dec 19, 2022 at 2:43 PM Post #2,164 of 2,691
for what its worth my DX3 is at 50-53 And new 4.2 is available
Dec 19, 2022 at 2:57 PM Post #2,165 of 2,691
Thanks for the feedback.
Despite the common temperature readings between another EX and your DX3, and not being familiar with processor HW temperature operation, it still remains notable to me that there is a >30 degree F difference between my CX and EX.
I can only assume that with the more powerful CX processor, it is idling along temperature-wise at its 9% CPU usage compared to the less powerful EX at 3% usage.
I dunno.
Dec 19, 2022 at 3:00 PM Post #2,166 of 2,691
I dunno.
I believe the CX is liquid cooled while the EX has just fins.
Dec 19, 2022 at 3:22 PM Post #2,167 of 2,691
That all adds up to me.
Also, just heard from Mark who specified his OLADRA at 39C and DX3 at 55C.
Just wanted to make sure long-term reliability of my EX would not be shortened if the temperature was higher than normal.
Dec 19, 2022 at 3:40 PM Post #2,168 of 2,691
Wow - that certainly would explain why it runs so cool. The K50 with no music playing is now at 41C (player) and 45C (server).
Dec 19, 2022 at 5:28 PM Post #2,169 of 2,691
Have you upgraded to the K50? Your sig still shows the K30.
Dec 21, 2022 at 6:57 PM Post #2,171 of 2,691
Dec 21, 2022 at 8:27 PM Post #2,172 of 2,691
I’m gripping my dx3 as you all know
Dec 27, 2022 at 7:15 AM Post #2,173 of 2,691
How do I disable the up sample in squeeze, I have read where you change a setting in the plugin C-3PO. Looked in there but not sure what the setting is called that needs changing?
Update I have found the setting so all good now.
Dec 27, 2022 at 1:04 PM Post #2,174 of 2,691
Removing the plug-in would be the easiest path to disabling upsampling. Go to plugins and uncheck it.
Dec 27, 2022 at 2:29 PM Post #2,175 of 2,691
I found the way to disable upsampling and keep plugin C-3PO active so I can play PGGB files.
Not sure why the settings had changed to upsample the files, maybe it was to do with the latest update from Antipodes.
