https://thecustomart.com/shop/universal-fit/fibae-5-universal-fit/Is there universal version of this F5 ?
Thanks
CustomArt FIBAE Impressions Thread
- Thread starter piotrus-g
weexisttocease
Thanks
Not sure if it is possible to order universal fit with custom design.
hongky
- Mar 13, 2013
Is this also come with filters ?
Thanks
mashuto
- Sep 23, 2016
It is. Pretty sure @F700 in this thread has a universal with a custom design, though in that case it was just clear. What I was told by Custom Art is that they can do custom designs for universals, but the shell itself has to be clear or black, then they can do any custom faceplate. Though you have to contact them since there is no designer for custom universals on their website.https://thecustomart.com/shop/universal-fit/fibae-5-universal-fit/
Animagus
Reviewer at Twister6
Thanks
Yes all FIBAE 5 come with the filter to turn the bass shelf down by a couple of dB.
Silverlinings
Anyone use the F7U for metal and prog? With the musicteck sale I’m thinking about pulling the trigger to compliment my Mest mk2’s
Animagus
Yup and I really like it! Anything specific you're wanting to know?
I mostly listen to prog metal and metal core so that should give you an ideaAnyone use the F7U for metal and prog?
Animagus
I mostly listen to prog metal and metal core so that should give you an idea![]()
Let's see your metal face then!
Deathman666
I mostly listen to metal and fibae 7 unlimited are amazing for this music. The coherence is almost unbelievable, nothing is missing, nothing is left over. I definitely recommend it for guitar music.
I also listen to mostly metal with my F7U and it's pretty sublime. Actually I decided to swap my customs for the universal version, so I'm patiently waiting to get these babies back and headbang again!
Silverlinings
Thx guys..guess there is no question now…
- Jul 3, 2013
FIBAE 5 in the house:
Will take them to work for some listening with/without filters and then measure the frequency response over the course of this week.
