elnero
Not much that I've read. This the only thing I remember reading offhand. Quote:
It should be noted that contrary to many posts I've read as stated above the Black is not just a Blue in a different package but a completely new design.
Originally Posted by mshan Any comments on those forums on if / how the DA10 compares sonically to the Lavry Blue? |
The sound will be very similar. The design of the DA10 is completely new, but the basic approach and design philosophy is the same, especially in terms of the sonics. I would choose the blue for multi channel applications in a LavryBlue chassis. The black does offer some additional features - volume control, coaxial input and optical (toslink, light pipe). If you have a Blue, and need more channels, I would add blue DA cards. If you need the volume control feature, I would opt for the black. If you must have optical, I would go with the black, the blue does not have optical. If you need an RCA (coaxial), you can use either (the blue can be made to receive coaxial with a simple $10-$15 XLR to RCA adaptor. The black can receive RCA directly. If you need a headphone, the black is the choice.... Regards Dan Lavry |
