In case anyone want to play around with my data on your own, you can just import the raw .txt files on REW. I know some of you are already seasoned, but a lot more aren't so I'll just run a step-by-step just in case.
1. Download Room EQ Wizard (REW)
here
2. Import the .txt files using Ctrl+I or simply by going to File -> Import Frequency Response
3. Play with the graph settings with the button called "Limits". Default scaling that I use would be 30dB/90dB on y-axis and 20Hz/20,000Hz on x-axis, but of course you have all the freedom to play with that all you want.
4. To overlay, import all the graphs that you want and then hit the "Overlays" button. Adjust the scaling with the same steps in step 3.
Final product should look like this:
@castleofargh already laid out my train of thought regarding this; if the default tips are weird or whatever I'll still be using it since, well, it's the default. I'd be happy to play around with tips but I think I've outlived my welcome in Jaben Melbourne. All this is done on a "when I have time" basis, after all.
