JohnYang1997
But I will try the behringer ecm8000 since it's pretty cheap and it looks really promising.
coupler (together with insertion depth) seems to be very important to get closer resonances to reality (so freqs peaks and dips are located more accurately), i think we all agree on that.
but if you are willing to be pretty accurate above 10kHz.. both coupler and mic tolerances are big in this area.
coupler error: Freq range: 20Hz-10000Hz; freq response: ≤±0.5dB(200Hz-5000Hz),≤±1dB(<20Hz-10000Hz) -> you can imagine the error above 10kHz.. it could be >±3dB at 16kHz, for example.
mic error: my "expensive" condenser mic freq range: 20Hz-16kHz; about -3dB at 20kHz. iMM-6, 20Hz-10kHz. cheap electrect, could be like 20Hz-8kHz, for example.
error goes high and manufacturer doesn't guarantee enough stability/consistency outside the range.
you can try to calibrate your mic by using a calibrated high precision mic or by comparing to relative reference measurements, to minimize this error, but i guess a cheap mic will be prone to "loose" this calibration sooner in time and in range than a preciser mic.
i've just received a well calibrated ecm8000 and shall try to calibrate all my mics using it.
but ecm8000 is not ready to be screwed into our couplers, like you have read in @castleofargh post (and impossible to fit in your base/coupler stand). and it is a free field mic (rather than pressure mics, more suitable to be used in our iem couplers). more investigation is required..
Holy f..s...there is accessory like this? Had rode vxlr but didn't see the vxlr+! Just ordered.yes, these cheapo chi electret are a true value. you can get a +48V phantom to 9V adapter to use them in your focusrite. got rode vxlr+. or you can diy..
I really wish you to get some thing to compare to ra0045 or 4157/4195. Like the certificate from etymotic. It shows that er4s er4sr er4xr should have a almost flat plane 10k-16k. This is the next best thing to the recommendation stated in itu p.57. You don't need to screw the coupler of AWA or anything, just use the stock mic. I am pretty sure that even AWA won't get it right at 13k, but should be better still. Er6i with resistor is another next best thing to er4's. I have a friend in China has crysound711 and bk4195, but no gras or awa. Crysound being supposedly better than awa can't get it right. But very accurate and low distortion before 10k. I sure need to save up for a second hand ra0045, there are three of them that I know cost 12000 cny/rmb or 1600 usd roughly.didn't get such discrepancy between my couplers (above 10kHz) when i tried (check the couplers comparison graph from my post). couldn't compare to the new coupler, because i don't dare to unscrew the fragile mic yet.
can't compare old couplers again because got rid of one, but i'll be able to compare with a new cheap ($13+shipping+fees) "711" coupler i got. but it will take long, many urgent tasks to do before.
The answer to that is. If you have a iec 711 coupler, and setup your er4, then open arta spectrum analyze or fr2 window, you will find a depth that gives a highest 13k. That is the correct place for er4. I insert deeply to the 2nd bend as stated by rin ages ago/so deep that you cant hear your own voice clearly lol. As er4 being one of the rarest non custom earphones that have almost flat response 10k -16k. And the reference plane is where the coupler measured in development suggested in itut p.57. Making this imo the best way to evaluate a simulator on our own.there is a double issue with the ER4 certificates. the silliest change in insertion depth will throw off the response in the trebles, so we'd need to have a strict reference and be able to stick to it. but then is it the deep insertion expected to be used by the listener? if so what about all the other IEMs that can't go that deep? or is it the standard distance to reference plane? in which case, does it mean anything to have a system aimed to model an average human ear, if we measure the IEMs at the wrong insertion depth?
and the other little point worth mentioning, they calibrate the IEMs by placing them into their rig with a mold of their making instead of using standard tips. the aim is to get rid of some uncertainties potentially caused by how the tip is inserted, but as a result it's not exactly what we do and we do not know if it would really measure the same.
that said I'm very happy to have such a certificate, because better have an approximate reference than no reference at all.
Stick to your hearing, will be better if you can demo some high end near-mid field speakers like event opal and adjust eq yourself.yup I was talking about sticking to standards. my own use is 99% for my EQ, so of course I try to match the insertion and resonance frequencies to what I'm getting in my ears. and I accept that this is no standard measurement. having insertion difficulties with some models really make the IMM6 and a silicone tube great. it's easy to measure the distance, with the transparency. it's easy to adapt to any special need. while it's not standard to anything, it's really convenient. ^_^
