Falkentyne
- Mar 26, 2010
Another firmware update 1.61.01.
I don't understand why Creative can't just release a software version of Super X-Fi. Can the chip really do more calculations than my powerful PC??? I would rather have wi`ndows process it through an app and then send the signal from my high quality outboard DAC and AMP to my IEMs then use the X-Fi which is sure to hiss. If I buy the X3 can I just do all the processing in software???
Ah, that does explain it, thanks. Hope they make a hifi version thenThe SXFI App on mobile is the software version however it isn't the real thing.
The reason why they sell them on chips is to protect their codes. Something developed over 10 years can be stolen in a matter of days through software reverse engineering.
I never looked after that but i saw there is a usb device that you plug between to usb to measure the voltage and current. But my sxfi amp is louder on my pc as in my ohoneCalling all SXFI AMP owners with windows PC can you check how much MA your amp is pulling says on the amp itself and the box 5v==500ma. Mine is registering as only using 100ma using usbdeview and usbview. Curious if its the same for everyone or just something wrong with mine.
How come on the SXFI amp itself it says it will draw 500ma? Also I own the Hifiman HE4XX and I have to turn it up to at least 70% to get good jammin volume.
Ok thank you for explaining. Both my keyboard and mouse draw there max thought that's how other usb electronics worked.It just mean to be used in a USB port capable of 500mA. You can go look at all USB products, what printed is not the actual current draw. How much power it draw depends on the load!
Similarly, your PC's PSU of 600W does not mean it draws 600W all the time.
