interpolate
- Feb 26, 2015
A very detailed review...the kind that Ars Technica used to produce.
Fair point. Still, it does support Dolby Digital Live signal and does work with consoles 9as far as audio goes, chat is another story)
Ok I hope so cause im gonna pick up the X7 tomorrow.
Total forgot to update this but i ended up buying a power supply here
http://www.aliexpress.com/item/Free-Shipping-AC-110-240V-to-DC-24V-6A-power-Adapter-Converter-with-power-cable-PA/32219461012.html
only $26!!
only $26!!
Just make sure you tell them in the comment when ordering to change the DC from 5.5*2.5mm to 5.5*2.1mm
It works perfectly for me.
I do have one question though and I swear it has been answer but I am unable to find where I read it.
to use the increased power supply I have to change the Ohm switch to 4, but in your test you said you used 8ohm, how?
Did you just change it to 4ohm, turn on the increased power in setting then switch the Ohm switch back to 8? i did this but don't hear a difference.
and it runs my SP-FS52 Speakers perfectly, bloated bass but that's the speakers rather then the X7.
just bought the E-MU XM7 to go with the X7. Went for the brown cabinet option. They'll arrive later this month (such a long wait!). I received a coupon code for 70 bucks off so it was too good to pass up. I'll have saved 170 bucks on my x7 and speaker combo when all is said an done. I"ll have to test it out with and without a sub to hear a comparison.
Thanks for the info! Wow that's cheap!
Looks smaller than the one use by Creative, hopefully no over heating.
FYI, you don't have to switch the impedance to 4 ohms. I use the 144 W power supply with 8 ohms setting, because I like the sound better on the 8 ohms setting. So you can switch to 4 or 8 ohms, find which one sounds better on your speaker.
Cool!
So are the 4 and 8ohm for speakers only? Or will it work for headphone?
I'm asking again if anyone else is having the issues as I'm still getting the problem of a hiss in the left channel in both Speakers &/or headphones & the crystal clear mic settings being ON even though the software is grayed out ? Wondering if its worth sending it back to Creative it see if its faulty !
