- Oct 14, 2013
Don’t have any helpful tips here for you. There are several cheaper units that is also adjustable. If the voltage is shown correctly, then it is what it is. Mine have been working just fine, and my psu can constantly be turned on, or triggered on/off anytime I wantGotcha, I've been looking on aliexpress and ebay to find a nice one. Seems to be a bit tough to find a quality built one since not much testing has been done on them to verify their operation. Any tips finding a nicely built one?
this ringing can be exhibitEd by both, either the host or slave device, and it is not easy to diagnose. There are multiple possible reasonsMine exhibits this ringing as well. Did you ever figure out a solution or even a definitive cause? I was doing some testing and my preliminary thoughts seemed to point to specific bit rates causing this ringing sound. But I wasn’t able to reliably replicate this. What lead you to believe this was a hardware issue?
