Andi-C
- Jan 26, 2015
Thought I had deleted this:
Thanks MLE, this worked ! Fingers crossed it fixes my issues...
How to setup line-in, SPDIF-in at 24-bit/192kHz in Windows?
When I set the default format as 2 channel 24 bit, 192khz in SPDIT in properties tab, it always fails and says the device doesn't support this format.
Did you set it to 'Direct Mode' ?
y
yes, in x7 control panel, right?
y
Oh I got what you mean, you need to use SPDIF input at 192 kHz right? Just set the recording device to X7 SPDIF and set to 192 kHz.
Under your system properties you can untick this under power management.
Right-click/select on My Computer > Choose Manage and authorise > Device Manager > USB Hubs and once you find the correct hub the X7 is attached to go to power management and deselect the option.
Sorry I'm not sure whether that's a hardware or software problem then, although I imagine that you can disable it through software. Try the Creative support for an answer.
Some are saying this is a hardware/software 'inconvenience' although as yet I can't point you in the direction of a way to fix this.
I'm getting some electrical buzzing noise every couple of minutes from my X7. It comes through on both speakers and headphones and can be recorded, meaning even the system seems to hear the noise ( meaning this is an issue happening before it gets to the speaker/headphones? ) Here's a link to 30 seconds of audio with the buzz noise:
https://www.youtube.com/watch?v=U8WhCbIKGPA&feature=youtu.be
Does anyone have an idea as to what may be causing this? It's very distracting. Buzzing seems to go away in direct mode, but when using effects such as surround sound or crystalizer, the buzzing returns. I'm using the latest control panel and firmware update.
Things I have tried to resolve the issue so far:
Muting all levels under the playback device other than Speakers.
Disabling onboard audio in bios.
Moving from a USB 3.0 to a USB 2.0 port.
Disabling all playblack and recording devices other than the X7.
