EasyEnemy
- Dec 9, 2016
Perhaps I'm not sure what I'm asking then. In short, then, is there a way I can run 4 passive speakers + a sub with the X7? If not, how do you/others feel about running a separate avr with speakers/sub from the X7 via an optical cable?
http://img.creative.com/files/guide/X7/SBX7_FAQ_EN.pdf
According to the FAQ Manual/Connectivity to Speakers/point number 10.
10. Can I connect more than 2 passive speakers to the Sound Blaster X7? The Sound Blaster X7 supports stereo, 2-channel audio output, and should only be connected to only 2 passive speakers at any one time.
I'm a layman so my explanation will not be very precise.
1) It is stated "only 2 passive speakers" so it is safest not to.
2) Having 2 speaker for each channel does not bring any improvement to sound as they are producing same sound. It might even degrade the sound as some frequency might cancel each other out.
3) You can try at your own risk for no improvement to audio (which I will question why do it in the first place). Before doing that make sure you fully understand about amplifier output impedance, electrical engineering stuff (serial and parallel electrical connection and calculating impedance), even before trying, you run the risk of frying your x7.
