Do you think the Sparkos are worth the price they cost? And do you by chance have any other amps you can compare to?
i would need more time to review them as I'm ill at the min and need to sit and listen to them for a long time.
i have a hdvd800, at-ha5000, schiit uber and non uber, bravo v2, a black cube linear and a copy one which is in my dah1. (i have most gaming type amps, minus the sennhiser gsx1000 and steelseries 800 wireless ones, and dss mark1. i believe i have all the others)
the hdvd800 and ha5000 are both Superior when fed from the hdvd800 (the ha5000 shows the x7 up as a inferior source when i a/b tested prior to the op amp upgrade.)
i cant really and fairly comment until i get used to the sparko setup then a/b them all.
i like computers and i feel that the sparko's are like putting a sli 1080gtx into an amd apu based machine, you feel like the sparkos are doing all they can with what they have, they don't feel like a weak link in the x7. which is reassuring feeling i suppose.
are they worth the money:
well when you get a new pair of headphones like the 668b or the cloud2 or aurvana live2, that sounds surprising, you smile and think "yea!" and they are all great value, you also feel like you got a steal.
i feel that way with the sparko, it sounds different and better but the value is not as much of a steal, its like i got what i paid for, i don't regret it yet, but I'm not about to recommend to my non music loving friend to go out and buy it (like i would recommend the cloud's if found cheap)
i agree with the other reviews of the amps so far and feel they explain and review them better than i could. (thank you to them!)
