muscular
- Jul 3, 2009
In order to get Neutron to ur Z2, you will need to have access to googleplay.
Neutron music player is an android apps, thus u need to access googleplay.
You do not need to root your Z2, but rather download the apk file from anythingbutipod.com forums, just do a simple search or go under cowon Z2 sub forums.
Sound effect soundbits? what's that? When u do start ur Z2, there's quite a few apps that opens automatically, ull have to manually stop them under ur ram.
The Z2 acts as a internet phone through some apps such as korea's preloaded kakaotalk. But u need to link it to your local wi-fi first. Z2 doesn't support a sim card so no way ull get mobile broadband.
^ Thanks for the info.
I managed to figure out using the CowonAmerica website which showed the step-by-step guide to it with some pictures. I guess I wasn't smart enough for the main Cowon website's instructions haha!
Now I need to start installing Neutron or what's it called - am I right?
Also how the hell do I get rid of these sound effect soundbits from my music folder? I get interrupted once in a while with device sound effects that shouldn't be there at all.
How do you use the Z2 as an internet phone? What do I put under "server"? I'm confused..
Many thanks for the answers/replies!
