Cowon PLENUE M2 (Current Firmware and Manual Links in 1st post)
Dec 16, 2016 at 12:49 PM Post #136 of 545
I took my friend to buy a cowon plenue m2 and i ended up buying one for myself.
So i am joining this nice thread. Also i bought fiio a5 amp and they fit exatcly the same size as if theu were made for each other
We tired all cowon s, p1 and m2 and they all sounded the same to us
So we settled for the plenue m2
Sounds the same?!
And was the m2 cheapest of the bunch?
Dec 16, 2016 at 2:29 PM Post #137 of 545
can i ask since this has no line out what is best to do when connecting the cowon plenuse m2 to an amp, should i put the volume on m2 to highest and control volume on amp or vice versa
Dec 16, 2016 at 2:38 PM Post #139 of 545
Set Plenue M2 to earphone mode with volume maxed and control volume with amp.
To my ears Opus#1 with latest firmware sounds better then this.
u mean turn off headphone mode ?
Dec 16, 2016 at 2:41 PM Post #141 of 545
Dec 16, 2016 at 2:54 PM Post #143 of 545
Dec 16, 2016 at 3:14 PM Post #145 of 545
It was posted here where to buy case. It's guite expensive tho.
so no other option for a case than the gmarket one, so u do not use a case with ur cowon
Dec 16, 2016 at 3:28 PM Post #147 of 545
I bought one from Gmarket too. I paid like 73 EUR total with import VAT.
i prefer to keep it naked then :)
for a case to pay so much is a bit too much, will see what i can put it in until other option become available
Dec 20, 2016 at 7:58 PM Post #150 of 545
can i ask what volumes do you usally listen to with m2 and iems with high or low gain, can you give examples which iems and at what volumes?
  • Back
