I use iBasso it03 usually at 50-60 low gain
Cowon PLENUE M2 (Current Firmware and Manual Links in 1st post)
- Thread starter taffy2207
Sound Eq
- Nov 9, 2013
and on high gain, can u give me an example of a song that u listen and at what volume, u and i have the same set up ibasso it03 and m2 which sounds amazing together
sometimes I like it louder , for example Rag'nBone Man -Human
on it03 I dont turn on high gain, I also have Beoplay H6 and then high gain at 60-70 but of course it depends on the mood but I'm trying not to listen too loud and I play a lot with EQ
Sound Eq
- Nov 9, 2013
i am adjusting to listen now on from 45-55 on high gain, and to do this i first listen the first 5 minutes on low gain at 50 then i engage high gain between 45-55 before i was listening at around 60 high gain
so i listened to human and with that song my volume would be 45 on high gain, and its how i like the volume to be
i guess in the end it all depends on the mastering, for example some albums i have sound awful at 45 high gain and very low in volume, while for example the song human sounds great at 45 on high gain. For example the song Hello by Adele at 50 on low gain ( i know cheesy ) sounds awfully low at 50 on low gain, to me it sounds as its at 30 and is totally not enjoyable at 50 on low gain. Maybe you can try it and tell me how you would listen to that song and what volume
maybe @twister6 can you chime in and tell us at what volumes you listen to and with which iems, lets take for example hello by adele
on another note its pretty sad that there is no precense of cowon what so ever on head-fi that we can interact with
You are right, lots of albums are mastered differently, old ones are recorded at lover volume , modern recordings have increased loudness.
When you have a chance check Kate Bush - "Running up That Hill" or any Mike Oldfield old songs like "To France" .
personally I prefer lower volume recodings, they are more detailed.
https://en.wikipedia.org/wiki/Loudness_war
Sound Eq
- Nov 9, 2013
well the song hello is new can u test it and report back
I know that song very well so we have same player and use same IEM, I turned the player to "normal mode, no EQ, 16bit Flac Hello sounds good to me at 30-35 high gain and at low low gain 40-50 . I also have 24bit Flac of Adele and its noticable less louder than 16 bit FLAC
- Oct 6, 2013
Does it matter?
Sound Eq
- Nov 9, 2013
you are right, so i guess you are listening at explosive levels that's why do not want to tell ---- just kiddin
that's not the first time I hear about the Cayin i5's lower frequencies distorting when boosted.
I wonder what Cayin has to say about that..
if it's hardware, or if it can be addressed via firmware update.
I have a Cayin i5 and I will test it when I think about it but I rarely EQ and I am not sure why you would boost the lower frequency in the i5.
Bastianpp
- Aug 11, 2016
Someone have this same problem?
- Oct 6, 2013
Can you please let us know about the problem? Is the micro USB connector misaligned or something else?
Bastianpp
- Aug 11, 2016
The usb micro connector can't enter full on my plenue m2, if i move the cable in dac usb move i have a problem of sound on my listening.
The usb is loose, is not the cable is my plenue.
- Oct 6, 2013
So, I assume you tried it with a different usb cable and it's still the same? Has it ever worked for you before, out of the box when you first got it? Either way, sounds like you probably need to contact the seller to service it under warranty.
