rockwell
- Dec 17, 2014
thanks to vitor for creating this thread.
this is the problem i have with my plenue d:
i have my 2nd plenue d replacement (so it's the third device) and this one also has the inconsistent sleep and stand by behavior: http://www.head-fi.org/t/789488/cowon-plenue-d/3060#post_12716397
five out of ten times works properly: plenue d has it's screen of (for me "auto display off" after 10 secs) because it's in my pocket, then i have to take it out and unplug the phones, playback pauses (apparently) and then it goes to sleep (for me "auto off" after 1 min). that's just how it should work...
but in the other five cases it keeps just it's screen dark and does not go into sleep. and i'm not talking about the sleep timer since this is off on my device:
<< "auto off" setting to 1 min.
<< and then after 1 minute (more close to just 40 seconds) the plenue d goes to sleep like this after i unplugged my phones while a track played and while the screen was dark because of my "auto display off" setting. and this is what i want my plenue d to do (and should according to the settings) but happens scarcely unfortunately.
i also made a threat at the cowon forum: http://www.cowonglobal.com/zeroboard/zboard.php?id=B16&page=1&page_num=20&select_arrange=headnum&desc=&sn=off&ss=on&sc=on&keyword=&no=43605&category=51&bmenu=support
they replied:
is it possible to reply to cowon's response? or do i have to create a "new article"?
i still have to check whether playback pauses in the cases where sleep does not work properly. it is my impression that it actually does not pause the playback and due to this the plenue d is not really inactive and therefore does not go to sleep. i also want to check if this happens depending on the filetype. about 60% of my library is .alac. nonetheless, it seems to be headphone and cable independent. i tested it with: dunu titan 5, atomicfloyd superdarts, koss porta pro, and 2 aux cables. it happens in all of those setups. it is also firmware independent. i use dapper to transfer my itunes library to the plenue d to my 128 gb card (nothing on the internal storage). dapper settings: no invisible files are deleted.
any suggestions what i can test are greatly appreciated.
they replied:
Dear Customer,
Thank you for your interest on our product.
Sorry for making the inconvenience when using the device.
It seems that there is an intermittent problem with sleep mode.
Your valued feedback has sent to development team and we will try best to resolve the problem.
We will try to solve this problem as soon as possible.
Thank you for understanding in advance.
Have a good day.
