Vitor Valeri
- May 8, 2011
I believe we are having different problems with our player. You are hearing noises only when exchanging tracks when the display is off. My player is producing noises when playing mp3 with the display off.
AFAIK, no one else is having the problems I am facing and I had run out of ideas on how to fix the issue. So I decided to return my player back for repairs. I dont know if it is a software or hardware issue but I hope they would sort it our soon.
If no one else is having the same problem as you are having, then I suggest you send it back for repairs / exchange because this is not normal. Good luck
Read the comment "01.21.2016 16:23 [19511513]" (use google translate) that this link: http://bbs.kakaku.com/bbs/J0000017959/SortID=19459284/
I recommend also reading the other comments.
For me it was clear that it is a software problem. I'll wait for the next firmware to see if the problem resolves.
In one of the comments says he thinks the problem occurs when there is a silence in music and the system understands that is not being used, then the system powers off and on, causing the noise.
