Cowon Plenue 2 - Taking it a step further.
Mar 15, 2018 at 8:29 AM Post #737 of 1,025
Well the Cowon P1 just got an update? Huh.... Months now and the P2 nothing. Hoping to see updates for current issues to be fixed.
What issues are you thinking about ?
Mar 15, 2018 at 11:19 AM Post #738 of 1,025
The latest release on the P2 has a “skipping” on the volume via the knob and the volume touch. Another member reported this on the thread and I tested it and I agree. When you go volume up or down either via the wheel or the touch screen, the music is not smooth and you can hear it skip a step down in volume. I tested on my P1 and although it does not have a volume wheel it does not do this on the touch volume like it does on the P2.
Reply from Cowon: 10/25/2017
Hi!
Thank you for the information you provided.
Our headquarter will review this if there will be anything can be amended.
Regards,
JetAudio, Inc
www.jetaudio.com
No update still.
Mar 27, 2018 at 10:25 AM Post #739 of 1,025
Well I finally received a reply;
Hi!
What we were told from our headquarters are as below.
While controlling volume, the music playback cannot be smooth sometimes. it usually happens when jetEffect is on. However, it happens sometimes when jetEffect is off. It’s kind of normal symptom. So, please understand that it could be P2’s kind of characteristics.
Sorry for not giving you the positive answer.
Regards,
JetAudio, Inc
www.jetaudio.com
Mar 30, 2018 at 7:48 AM Post #740 of 1,025
So now I have original Samsung OTG Adapter. Now it´s working, but I have a Problem. The playtime is running fast and there is no sound in my Earphones. Tried it with S7 and S8 same behaviour. Does anybody know this problem?
I dont know why but with Android 8 (Oreo) its working now :smile_phones:
Apr 11, 2018 at 4:26 AM Post #741 of 1,025
A quick question for P2 owners: does balanced output give any perceived added power for headphones vs. the SE - i.e. not only more control and dynamics, but also some loudness? I've just acquired a used unit and was a bit surprised that it doesn't yield enough loudness for the 2016 LCD-XC on SE. With some tracks it works, but others lack ultimate loudness and tend to sound anemic.
I know that the P2 MkII balanced could fix this issue, but a €600 upgrade from my used P2 is too pricey for this issue alone.
Also, melodic instruments and voices sound a bit unnaturally thin on SE - do they feel any thicker or more present with balanced output?
Jun 7, 2018 at 5:12 AM Post #742 of 1,025
Bought latest 256gb MK2 from advanced mp3players just now with coupon AMP500 which gave a bargain 15% discount, thanks to reading headfi.
I was waiting for the new AK100 but the Cowon mk2 has 256gb and the similar dac to the ak sp1000 which is 3 Times the price, I am celebrating....!!
Jun 16, 2018 at 2:25 PM Post #743 of 1,025
How do you find the Mk2?
Jun 16, 2018 at 2:41 PM Post #744 of 1,025
i assume u are not using eq, from my experience with cowon i think they only sound good with eq
aslo u are talking bout audeze lcd xc that needs a powerful source , so changing daps will not get u anywhere. forget specs on paper with such headphones you need a powerful amp
my cowon plenue s does not drive my lcd x or lcd2c at all they way that should sound
Jun 18, 2018 at 1:18 PM Post #745 of 1,025
I really like the mk2 because of the extra memory and really, really excellent equaliser. having used the ak70 for the past year it is a revelation to be able to plug the Cowon into my iMac and it just works with transferring music, it works ALL the time, every time. The ak70 is a right pain as it constantly disconnects and you have to manually change it back to file transfer...this is a joke!!
The operating system on the Cowon is also excellent and I have been able to fully customise how I want to use it to my preferences. It loads 80gb on internal memory and 200gb on a micro sd card within 12 seconds from switching on and ready to play....amazing.
Equaliser is something I have never been able to use on ak70, the Cowon is a joy to use and so simple and VERY effective with a massive choice of settings.
All in all as you can tell I am very happy with this machine it is a pleasure to use.
Jun 18, 2018 at 2:16 PM Post #747 of 1,025
Thanks.
I've just placed my order! :)
