according to google translate HIFI Chris wrote that balanced output on Plenue 2 is not real so to me it means it's fakeIs that part of Google translate? It sounds real to me and I like it over SE one
Cowon Plenue 2 - Taking it a step further.
- Thread starter Niyologist
- Oct 6, 2013
This could be interpreted in different ways. For example, there is absolutely no difference between BAL and SE in X5iii, but it's convenient to use one vs the other if you already have balanced terminated cables and don't want to use an adapter. With DX200, BAL output doubles the voltage swing and power output, that's a true balanced architecture of rail-to-rail full voltage swing design. And then, you have a lot of other implementations in between where balanced output gives you some subtle improvement which is not as drastic. I can't speak for Chris, and I know that he doesn't just rely on his ears but takes real measurements. I can just speak from my own personal perspective of what I hear, and just like with many other DAPs there is no night'n'day differences, but I do hear the improvement as I noted in my first impression mini-review... When I get to finish the full review, I will spend more time with BAL vs SE comparison, especially now since P2 has more burn in hours.
ouch, I was not aware that my P2 has fake balanced output
It might be a slight Google Translate misunderstanding - I wrote "not 'real'" with quotation marks, indicating that it shouldn't be interpreted as if the Plenue 2 was using a "fake" balanced output, but rather that it doesn't have a fully balanced internal structure (dual-mono signal path), but that the balanced signal is only "made" right before the 2.5 mm output.
In contrast to the DX200 and Luxury & Precision L3/L3 Pro (volume-matched with meters) where I was able to discern some difference between the balanced and single-ended output, I was not in case of the Plenue 2 (using my LCD-X and the SIRIUS - no other IEMs and headphones since I am not really a 2.5 mm TRRS/"balanced guy" in general).
I also wrote that, while it is a little sad for me and doesn't add much of a value in my opinion except for not having to use adapters, it is the implementation that matters in the end, and the P2's implementation is very good in my opinion, wherefore having the exact same sound (to my ears) coming from the balanced and single-ended output is certainly not a bad thing and that there is a good amount of other DAPs that isn't using a "real" (note the quotation marks again) balanced output either.
Ymmv of course.
Rockcoon
- Feb 23, 2015
HiFiChris, as i understand you don't hear a big differece between P2 and DX200. i've read some impressions of DX200, where people talking, that it has a bit restricted (or better say- recesed) vocals. Is it also fair for P2?
- Oct 6, 2013
Where did you read this DX200 impression? Do you have a link? I'm due for a good laugh
Rockcoon
- Feb 23, 2015
On our local forum. It's lost in endless ocean of massages about glitches and touch screen phantoms . But it was noticed by several people. I can try to request them.Where did you read this DX200 impression? Do you have a link? I'm due for a good laugh
Btw, Twister, what do you think about differences in reproduction of middle frequencies between DX200 and P2?
- Oct 6, 2013
Let me take a wild guess, "our" local forum is player.ru? Only visited it once, got a headache from reading it (it's been awhile since I read in Russian), but did see Cleg being regular in there. I also saw in there someone trying to translate my P2 impressions
Regarding middle frequencies, I think I already replied to you in a few other threads awhile back (probably in Opus and DX200), it's not about source but your headphones sound sig and their pair up with your source. If either of these DAPs would had high output impedance and you are using multi-BA iems, there could be a possibility. But these are all neutral sources with low output impedance and just a slightly different tonality, varying from warmers to brighter. Typical "vocal" frequencies shouldn't be affected. No manufacturer will tune their DAP like headphones with peaks and valleys to boost or to scoop out frequencies. Maybe some will have more bass boost or rolled off treble, but typically they have a relative flat frequency response. It's usually about the signature of your headphones and their pair up with your source.
Rockcoon
- Feb 23, 2015
Yep. It's pleeer.ru. Cleg posting video reviews and moderating there, he is a local Jude i thinkLet me take a wild guess, "our" local forum is player.ru? Only visited it once, got a headache from reading it (it's been awhile since I read in Russian), but did see Cleg being regular in there. I also saw in there someone trying to translate my P2 impressions
I can't allow myself to make another mistake and pay tons of cash for peice of... audio gear, which after few months of listening will be sold at half of it's initial price, cuz it's sounds awfull with any headphones. Unfortunately I have no oportunity to listen something before buy it. Only reviews and impressions can guide me.Regarding middle frequencies, I think I already replied to you in a few other threads awhile back (probably in Opus and DX200), it's not about source but your headphones sound sig and their pair up with your source. If either of these DAPs would had high output impedance and you are using multi-BA iems, there could be a possibility. But these are all neutral sources with low output impedance and just a slightly different tonality, varying from warmers to brighter. Typical "vocal" frequencies shouldn't be affected. No manufacturer will tune their DAP like headphones with peaks and valleys to boost or to scoop out frequencies. Maybe some will have more bass boost or rolled off treble, but typically they have a relative flat frequency response. It's usually about the signature of your headphones and their pair up with your source.
- Oct 6, 2013
But that means you have to find someone with exact same pair of headphones, listening to the same type of music, having the same ear sensitivity, etc. Will not be easy to find a review you can rely on 100%. Why not take a trip to Ukraine to visit Cleg? He gets all the review samples.
Rockcoon
- Feb 23, 2015
If Cleg get P2 for review, my journey wouldn't be necessary.But that means you have to find someone with exact same pair of headphones, listening to the same type of music, having the same ear sensitivity, etc. Will not be easy to find a review you can rely on 100%. Why not take a trip to Ukraine to visit Cleg? He gets all the review samples.
Here one of the messages about DX200 vocals:
http://player.ru/showthread.php?t=162055&p=2179182&viewfull=1#post2179182
Vocals is not drowned or veild, it's just not expressive, flat. Vocals is not the best thing in dx200. But it has splash on treble and infra bass. If you like infra bass, this is your DAP
jmills8
Previously known as bmiamihk, jmills2
DX200 was and is flat, cold, buggy and emotionless.
- Oct 6, 2013
That's why they released AMP2 amp
jmills8
Yrue, I bet the #3 Amp will make it better. Intetesting how many said the stock amp made the stock DX200 sound better than the Chord Hugo and AK380.
- Oct 6, 2013
Perhaps those people have preference for a more neutral analytical sound? I'm still waiting for AMP2, but so far every impression sounds promising.
But back to Plenue 2 discussion
Rockcoon
- Feb 23, 2015
That would be nice. This morning used Lotto Paw Gold in almost perfect condition just for a 1300 bucks slipped away from me, so I want to drown my sorrow reading impressions of P2But back to Plenue 2 discussion
