Mooses9
- Feb 12, 2009
Are you allergic to science or something?
se
LOL
il vostro mi sta uccidendo!
se
No, not at all, I like science. But I have nothing to contribute in this context which would be of value for the Sound Science forum. I was there for a while some time ago, and by hindsight it was fruitless.
We know nothing of the other properties, such as wire gauges used, construction geometry, dielectric materials, etc. But if you want to try and look at differences between copper and silver, then the ONLY difference should be the metal itself. Everything else about the cable such as wire gauge, construction geometry, dielectric materials, etc. need to be IDENTICAL for both cables. Otherwise, you're changing variables OTHER than just the metal used and you can't say you're comparing copper to silver.
se
Well everything else can't be identical. If the wire gauge is the same then the resistance will be different. If the resistance is the same then the wire gauge and other factors will be different.
On the subject of IDENTICAL - with modern test equipment no two cables (even the Left & Right in a pair) will have identical physical properties.
But as I wrote above (post #14) the differences between physical properties of copper and silver are about the same as a small different in the length of a copper cable.
So then what was the point of your posting in a thread having to do with measurements?
...But some seem to believe that there is a mysterious "something else" going on.
Well, as long as nobody has a reasonable theory, it's indeed a mystery how different cables with virtually identical measuring values can sound different...
There's no mystery as to how that can happen to anyone who has any understanding of human hearing.
That's the approach of which the Sound Science forum is full of: certainties. True science is open-minded.
Do you have any reliable data to support this notion? There are links in this forum that show there is no audible difference. I would suspect that any testing conducted that proved otherwise was more than likely faulty or unreliable.
Um, where is the certainty in what I said?
I see you're in Switzerland. Do you understand what the English word "can" means in the context that I used it?
Your semantics can't hide the certainties you both carry in your minds. You'll find your playground in the Sound Science forum. This section isn't meant to prove anything, it's more about personal (listening) experience.
I'm interested in measurements – to compare them with my listening impressions or e.g. get a better sense of the EQ characteristics of the FiiO X5 like recently. I think you have a too narrow view of my audio approach.
