superjawes
- Apr 2, 2014
prot is letting this get heated, and that is unecessary. There's no reason we can't remain civil.
Now, on the topic of dogma, opinions, etc., I will start by repeating what I have said before: there is no audible difference between "good" cables. Unless the cable is fundamentally broken, the electrical differences between the two are negligible. I will also add that many of the arguments for cables are often dogmatic, based on personal experience without controls, and subject to human error and expectation bias.
Cable properties well understood, and we have data to back it up. You can measure them to learn their properties. You can easily tell which one has lower resistance and/or capacitance, and therefore tell whether one is good or bad. You can easily predict the length at which a wire's expected behavior breaks down and starts to alter the signal going to the speaker (as opposed to just passing it through). There's no magic involved.
So I do take offense when someone calls me the "thought police" for presenting something that can be independently verified. Especially so because I work with wire harnesses for a living...
Now again, it is fair to praise cables for physical properties. A new cable can add some personality, some extra ruggedness, or convenience. These are all good reasons to replace the stock cables (which I am assuming are good to begin with). But if you take two good cables and put them in a controlled environment, the audible differences will be very small, if they even exist.
