dclaz
- Apr 10, 2012
Interesting. Are the HE-400's considered hard to drive?
There might be a difference in scalability between the two, but in general most modern headphones are not hard to drive at all. It's especially true with the relative sensitive planars like LCD2 and HE-400, because planars don't really change their sound depending on the output impedance of the amp.
Pardon my ignorance, but I thought things like the LCD2 were very hard to drive? And when you say their sound doesn't change, do you mean it's just quieter at all frequencies as opposed to softer in certain areas?
The LCD2 is not hard to drive. It's close to a resistive load, so easier to drive than any dynamic headphone in that respect, and fairly sensitive/efficient. Easier to drive than a K701 for example. Needs less current than the Custom One Pro, less voltage than a DT770 Pro or HD600.
In my table it is listed with negative gain, so your amp probably doesn't need any gain with the ODAC. Yeah, it's that easy to drive and yeah, most headphones are.
edit: http://www.youtube.com/watch?v=3I2lyIQDC24 shows the magnets which are pretty strong.
The change due to output impedance doesn't really matter here because afaik both O2 and Magni have close to 0 ohm outputs.
edit: But if you're interested: something like a receiver's headphone jack has a high output impedance. This causes, for example, a bass boost and loose bass with dynamic headphones. Planar magnetics are pretty much purely resistive loads so they don't really care about the output impedance.
So, if you switch from the Magni or O2 to a receiver with a HD555 you will hear a huge different in the bass, with a HE- or LCD or other planar magnetic headphone you won't.
It probably stems from the flawed logic that if a headphone is expensive, that it would follow that it requires an expensive amp to 'drive properly'. (Meanwhile, there is no subjective consensus about what it means when an amp is 'driving a headphone 'properly'. It usually translates to terminology such as 'tight control over the bass', 'opening up' the headphone, etc.).
Being one of the more difficult headphones to drive, a good amp is an absolute must.
Well sensitivity ranges from 102 (for the rev2, but we only have 1 data point) to roughly 109 dB SPL @ 1V. The ODAC outputs 2 V, so you can add 6 dB to that plus the gain of the amp.
As you can see, if you want 110 dB peaks you don't need much gain in your amp if any at all.
I don't agree with the "you need a very powerful amp" / "1W minimum" at all. It's nonsense.
If you listen to compressed music (pop, rock, metal etc.) then a fraction of this power is enough to cause serious permanent hearing damage only by listening to a few tracks.
If you listen to highly dynamic classical music, for example, then there can be short, loud peaks but on average the level will be much lower than with compressed music, so you'll never need 1W of continuous output power.
The Audeze guys speak of music with 60 dB dynamic range. That is realistic, but what's weird is that they also set the noise floor to 60 dB SPL. A 60 dB noise floor? What concert hall has a noise floor that is as loud as someone talking into your face?
Silence in a concert hall is maybe around 30 dB SPL. Even if the orchestra produced highly dynamic sound in a well-optimized concert hall with a range of 70 to 80 dB it would still only be 30 + 80 = 110 dB SPL peak.
So even if you pick the more inefficient rev2, listen to music with an annoying dynamic range of 80 dB and turn the volume up so that peaks will reach 110 dB SPL you only need about 100 milliwatts max. On average the amp won't have to output more than <10 milliwatts. The O2 outputs over 600 mW for 33 to 80 ohms.
edit: Only with something like the HE-6 you'll need a much more powerful amp, maybe even a speaker amp. If you read reviews of HE-6 & EF-6 you will see how bias affects what these people hear. "It's very clear sound" etc. but measurements by the German Audio magazine have shown a signal-to-noise ratio of only 75 dB. That means that fine details of the highly dynamic music mentioned above would be "overshadowed" by the noise produced by the amp.
Absolutely not. The HE-400 is more sensitive and efficient than the HE-500, which is not hard to drive itself.
With the ODAC/O2 you might even be fine with no (0 dB) gain, and less gain is better.
