adydula
- Dec 14, 2010
Even at the higher gain settings with the O2 your not going to get any audible hiss......if there is some its from your recording.
Alex
Alex
Alex
Having less gain makes sense from a technical standpoint, but with my STX, I prefer high gain and 20% volume to medium gain and 50% volume. Could it be that I subjectively enjoy the distortion more?
I agree, generally speaking the less gain an amp runs the quieter it is, and less prone to distortion. As above, if you need to wind the volume past 12 o'clock you could probably do with a bit more gain. Aim for ~50% on the volume dial as the maximum volume you will use.
edit: But if you're interested: something like a receiver's headphone jack has a high output impedance. This causes, for example, a bass boost and loose bass with dynamic headphones. Planar magnetics are pretty much purely resistive loads so they don't really care about the output impedance.
So, if you switch from the Magni or O2 to a receiver with a HD555 you will hear a huge different in the bass, with a HE- or LCD or other planar magnetic headphone you won't.
