That’s for sure, but it’s sucking so much power that my phone is empty in 5 hours. On an older or smaller capacity iPhone it would be drained in 4 or maybe 3 hours. You wouldn’t get trough a longer train ride with that…The KA3 has separate amplifier stage and is way more powerful, it will certainly draw more power than the Apple dongle.
Compact Portable DAC and Amplifier FiiO&Jade Audio KA1 Is Officially Released!
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
Yes this is true, not suitable for longer listening sessions.That’s for sure, but it’s sucking so much power that my phone is empty in 5 hours. On an older or smaller capacity iPhone it would be drained in 4 or maybe 3 hours. You wouldn’t get trough a longer train ride with that…
Maybe the KA1 will draw less power.
I can see that the trend is for more powerful dongles with increased power consumption.
Same as the KA3 is the RU-6.
Does anyone know how battery consumption compares with dragonfly black?There are two things that really bug me with my KA3. It drains my battery at about 5 times the rate of the apple dongle dac. The Apple dongle consumes 4% in one hour, while the KA3 drains 19% in my testing at the same volume. You can feel the KA3 getting relatively warm. For mobile purposes that’s not very ideal.
Under certain conditions the KA3 also picks up interferences from my iPhone 13 resulting in that beepbeebebeep sound that we all know from old crappy speakers.
Other than those issues, wich are not minor, the KA3 delivers exceptionally detailed and powerful sound.
I understand when the battery consumption is high when I have high gain high impedance and drive my 58X it needs so much more power and in that situation I am home and that is fine.
But the other time it drew so much power with low gain low impedance driving blon 03 at work playing low bit internet radio with dynamic policy on. And in this case KA03 was very warm which makes me believe software is buggy.
Ideal will be to have an option for home to eat as much battery it needs but also an economy mode for work or travel.
Samsung dongle is also good.
Hyde00
I forgot where I read but someone did a comparison chart with popular dongle dac power consumption. And all the Dragonfly all have lowest power draw due to their Gordan Rankin chip which is said to be super efficient. The opposite end is Centrance DACPort HD with highest draw and highest power output lol.Does anyone know how battery consumption compares with dragonfly black?
Only thing that has lower power draw is Apple Dongle, but it also has lower power output.
Otherwise Dragonfly Black is lowest follow by Dragonfly Red/Cobalt (same power, but both output more power than Black) then follow by everything else.
I use Dragonfly Red plugged into my computer permanently (it's on all day) and it's always cold to the touch.
looks more for a solution next to the Dragonfly, iBasso etc dongles and not to the Cayen RU6.
Yes, the power consumption of KA1 is much lower than the KA3.
Best regards
The KA1 does not support APP control in mobile phone currently.
But you could adjust the volume for KA1 via the FiiO control panel or the volume panel in the Windows computer when using it as USB DAC for Win10/11.
Best regards
Best regards
Luke Skywalker
These guys are killing me. ka3 has balanced that I want but no MQA. This new one has MQA but no balanced outI leave it at low impedance and high gain.
From the balanced output it runs most of my full size headphones with excellent results.
I think that it is because all the new , lower grade DAC chips from ESS have embedded MQA decoding.These guys are killing me. ka3 has balanced that I want but no MQA. This new one has MQA but no balanced out
Is the KA1 suitable for playing Apple Lossless Music (ALAC) in Apple Music on my Google Pixel 6 Pro? ALAC goes up to 192khz/24bit and KA1 supports up to 348khz/32bit, and Apple says a wired connection is required for listening to their lossless music library:![]()
This is a refined specialist with compact elegance.
In a tiny space of 40x15x8mm, there is not only a high-quality DAC, but there is also premium audio amplification to match, both carefully tuned by engineers to truly and faithfully reproduce your music the way it was meant to be heard.
Employed in the KA1 is the ES9281AC PRO chip from ESS, which supports 32bit/384kHz PCM and DSD256. You will surely be able to hear even the finest details within your music!
The KA1 combines USB audio interface, DAC, and amplifier into one package. When combined with the multi-layered HDI gold-plated PCB it is on, the result is lower crosstalk, higher efficiency through lower power consumption, and ultimately high quality pure sound.
The KA1 also supports MQA rendering in the DAC chip. Moreover, it has colorful RGB light indicators, which not only feature captivating looks, but also conveniently display the current audio format and sampling rate. iOS, Android smartphones and even Windows and Mac computers are all well handled. Dance with HiFi anytime and anywhere.
Keep features of the KA1 include:
--ES9281AC PRO DAC
--RGB status indicator
--Full support for a variety of devices
--MQA rendering support
--Supports 32bit/384kHz lossless audio
--Supports DSD256
*The KA1 is available on our AliExpress Official Store. Click the link below to take it home right away.
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.[/u]
https://support.apple.com/en-us/HT212183
Is KA1 enough or should I look for the BTR5 2021 and use a wired connection (USB-C to USB-C)?
I have a brand new pair of Fiio FD1 headphones by the way.
Thanks in advance for your response.
Yes. But if you would like to get higher output power, Bluetooth support, balanced output, you could consider the BTR5 2021.Is the KA1 suitable for playing Apple Lossless Music (ALAC) in Apple Music on my Google Pixel 6 Pro? ALAC goes up to 192khz/24bit and KA1 supports up to 348khz/32bit, and Apple says a wired connection is required for listening to their lossless music library:
Best regards
Like and follow the Facebook page Jade Audio and share this post on your timeline to win the FiiO x Jade Audio KA1:
https://www.facebook.com/JadeAudio.Co/posts/1373590429759479
It's so cute
- Home
- Forums
- FiiO
