shyamwanne
Was selling a Euphony PTS. But now it is sold
Do you also use a matrix?I have the Euphony PTS and sold my Innous Zenith mk2 because it sounded better. The Zenith was $4000.
If I had a few pound and I could buy a nuc or a matrix, which would you suggest ?
A NUC or something similar like HDplex that is a silent PC. The source is most important ie your server/music player. The matrix\x’s needs depends on your DAC. If it has a great internal USB bridge the effect of matrix may not be great unless u must have spdif/AES as input into the DAC for personal sonic preference or there is no USB input (unlikely). The euphony can basically be used on any PC but avoid new macs which are incompatible. U can actually load the euphony not just on sata but M2, optane drive tooIf I had a few pound and I could buy a nuc or a matrix, which would you suggest ?
First off, thank you for your reply Arthur, I really appreciate it.I would suggest you download the trial and test it from a USB flash drive on your current hardware to see what you think. That should help you decide what your next step might be.![]()
Hi Ken, That is part of the plan.You should seriously take a look at the Keces linear power supply and add that. That will be the slap in the face difference.
I am glad you held on to yours, I hope the wife understands.Good plan.![]()
I downloaded the trial and put it on a brand new USB 3 thumbdrive. After a bit of this and that I had it up, registered and running. It did not work plugged into my Cisco Switch so I pulled the Ethernet cable that supplies the switch and plugged that into the machine. Only then was I able to find the server via the web browser, the app on my phone and the app on my iPad.Oddly the same machine has no problem with the switch connection when running Win10.
What I found was a system that sounds very much like my normal windows 10 system with the Fidelizer mods. The Stylus app I could get used to, I like that Qobuz was easy to setup. It found my attached 2TB USB SSD, attached it with a click and found all the music contained. It's all alien, but I could learn it.
I do not think I am a candidate for the software running on my machine though. I am thinking I would rather have the PTS server in addition to my PC. I will send you and email and let you know what I am thinking of.
It's a very interesting system. Yes sir. It made my PC sound at least as good as it normally does, perhaps better. But it isn't the slap me in the face better, and I don't think I should be upset or surprised by that. It would be more fun to do a side by side with the PTS and my machine.
Anyway, I have 30 days left to play. I wish i knew what it's issue with my switch is a Cisco WS-C2960-8TC-L.
