timoteus
- Jun 22, 2001
I'll second and third Jude's opinion of DeoxIT. Fantastic product which is on sale at www.partsexpress.com Part number 341-200 5oz. for $7.55 I think.
Try this experiment to convince yourself that this is money well spent:
Pick and listen to a well known favorite song. Then power down and spray the volume pot. Rock back and forth for a few seconds and then give it one more squirt. Wait for the carrier fluid to evaporate and then power back up and listen. You will hear the difference. After this you will find yourself cleaning every switch, jack, and orifice you can find.
I also use ProGold but it is important to wipe dry or nearly dry after application. I have heard a few reports of builup after repeated applications. I have removed green oxidation off of perfectly clean looking interconnects before using DeoxIT and the ProGold will prevent reoxidation.
Tim
Tim
