Chord Mojo Modification ??
- Thread starter Kentajalli
As long as it can take 9V, it is OK.
but 16V is a little wasted on us in this case.
if that assembly fits inside, wonderful!
Sunrivers
Won't fit inside, 16mm is too thick.Each size is 16x26 mm.
3 would be enough if you can find a stabalized 8V powersupply (not charger).
Again, please look at posts above regarding getting the right size caps.
ecapsretliab
- Aug 13, 2010
Yes it would, but still needs some storage afterwards, in form of large capacitors, both for stable operation of device and transient current draw by Mojo.Any thoughts on just replacing the battery with an LT3045 regulator set to 8.2V?
Then just hooking it up to a 9V LPS via a DC jack mod?
Would this be a viable option?
I would put the regulator outside the device to make sure there would be no MRI and allow cooling.
If I am not mistaken the device requires 1.2V minimum to operate, so 9V supply won't work, needs 9.4V min. or more.
This voltage difffrence multiplied by supply current will be given off as heat.
Say 10V input, 8.2V output at 200mA means 360mW heat generation.
The pictured item is unlikely to be able to supply the needed currents, too small.
ecapsretliab
- Aug 13, 2010
Interesting, thanks for that. I think I'll eventually go with the SC option outlined earlier.Yes it would, but still needs some storage afterwards, in form of large capacitors, both for stable operation of device and transient current draw by Mojo.
May I ask, you mention...
"Better still, find a 9V LPS (easier to find), but add one diode in series, and a large capacitor or super-capacitor inside MOJO"
Could you please explain the "diode" part. I'm not sure of the parameters.
Thanks.
Since using a non standard Powersupply , a bit of protection against reverse wiring (polarity) is wise.Interesting, thanks for that. I think I'll eventually go with the SC option outlined earlier.
Thanks.
secondly, finding a stabalized 8.2V is difficult , but 9V is easy.
By using a diode you achieve both safety against reverse polarity and the 9V drops to 8.25V !
the extra 0.75V is diodes forward bias voltage.
If you are going for super-capacitors , make sure your Powersupply is current limited, or at switch on, you either pop the diode or the Powersupply !
ecapsretliab
- Aug 13, 2010
Since using a non standard Powersupply , a bit of protection against reverse wiring is wise.
I see, so a 1A 1000V on the + wire would be ok? I've never worked with diodes before.
Cheers.
Yep.I see, so a 1A 1000V on the + wire would be ok? I've never worked with diodes before.
Cheers.
it will subtract 0.75V from supply.
if 9V, then you get 8.25V at other end, regardless of current.
ecapsretliab
- Aug 13, 2010
Cheers, when I finally get around to it, I'll post my results.Yep.
Tjj226 Angel
- Oct 20, 2012
Why are you guys using super capacitors for this? Isn't the dac internally regulated? If so, the last regulator in the chain WILL be noisier than a decent quality lithium ion battery.
I am with you on this.Why are you guys using super capacitors for this? Isn't the dac internally regulated? If so, the last regulator in the chain WILL be noisier than a decent quality lithium ion battery.
In principle, I am against not using batteries.
However . . .
Many have decided to use their Mojo as desktop DACs - to this end, they like to hook it up to a power supply all the time.
So they ask, and I answer best I can.
Others have tried different methods, look above.
