discord76
- Jul 30, 2016
Does Mojo work with Windows 10 phones yet?
Check out the microUSB connecting Mojo section, but also be sure to read Rob's detailed posts section, which includes some discussion about upsampling and why it is best to avoid it, with Mojo.
I think...the phone has to support Continuum, then yes. If you google for it, I am sure you'd be able to draw a conclusion.
Mojo compatibility issue after the latest Win 10 updates despite re-install of Mojo driver.
Anyone getting clicks/pops/stutters when using poweramp or UAPP? Can't figure out how to fix it.
When I get that error message it's often a problem with the connector/plug/socket, i.e. loose connection or dirt on the metal contacts etc.
You have tried the ports on the PC, how about a different cable?
I have exactly the same issue. Only solved through UAPP, which makes all my streaming services bloody useless. Can't believe that chord thought that this was OK?
Might be resampling going on. I use a similar setup and absolutely hassle free.
Hey all,
Love the sound performance from my Mojo but I was wondering if there is any way to get streaming apps such as Deezer or Apple music to stop popping and clicking? I'm not a fan of Tidal at all, so is there a way to get the same functionality that Tidal has with UAPP through another method on Android? I already have UAPP for my local storage music and it works perfectly but I'm trying to get streaming working now.
It's driving me insane that such an expensive product with have such a glaring over site!
Thanks in advance!
Ok guys. I need to confess that I didn't try hard enuf yesterday. Actually there's no issue with the driver or whatsoever. I only found out today the cable is faulty. Now, with the new cable it is working fine.
Thanks all for the inputs & helps. Cheers.
Sent from my iPhone using Tapatalk
