Aha the root cause emerges - you live in a baking hot desert, and the internal ambient temperature in your house is hotter than most of the other Mojo users.
http://www.head-fi.org/t/784602/chord-mojo-the-official-thread-please-read-the-3rd-post/5865#post_12110900
As John Franks rightly says, the Mojo needs a certain temperature difference between the inside of the Mojos case, and the ambient air temperature in users room.
If the internal ambient temperature inside your house is say 20C higher than most other users, then the temperature inside your Mojos case will also be 20C higher - and this is probably why your Mojo is activating the thermal shutdown.
Mython is correct with the advice to stand your Mojo on its side.
The heat (Watts) that your mojo can dissipate to the surrounding air is proportional to the temperature difference, and the surface area.
If the Mojo is placed on its back, the surface area is approx (6*8) + (2*2*8) + (2*2*6) = 104 cm²
If the Mojo is placed on its side, the surface area is approx (2*6*8) + (2*8) + (2*2*6) = 136 cm², an increase of approx 30%, so the Mojo can dissipate 30% more heat.
Every time that I see someone complain about their Mojo shutting down on them, I glance to see where they are located, and for all the instances that I can remember, they are living in one of the hotter regions of the world (Dubai and Singapore, spring to mind). Possibly Chord should update their user manual, to advise users in those regions to stand their Mojo on its side.
