che15
- Oct 31, 2009
You might like the flc tech flc8s. Great IEM.
Thanks for the input, I am due to audition the ones on the loaner program sooner than later I hope.
Never tried IEM that was even close to the sonic experience of a mid-fi open back pair of headphones.
Just my 2 cents.
Portability justifies IEMs, of course. But experiencing limitless sound quality with no compromise is only possible with open back full size hps. IMO.
Just my 2 cents.
You are playing music out over the windows direct sound driver. You need to add the wasapi plugin to Foobar then set foobar to use the wasapi output instead of the direct sound. You should be able to google around and find guides on "setting up wasapi with foobar" otherwise you are going through the windows mixer which resamples audio to whatever your playback device is set to.
Yurivv in foobar go to file - preferences - playback - output - device - and you should see, chord async usb there.
Having just listened to the 8 Ensembles in One bit Dsd256 in Jriver 21 through the Mojo and a pair of He-500's my mind is blown.. Absolutely amazing!
I've already edited my previous post with the link you require...
There is a gap under each of my headphones out. Is this a problem? Seems to be a poor built...
Just my 2 cents.
That is generally true. However, iems now a days are not far off a midfi open back. For me, I think a good top end iem can compete with a good mid end closed back. Open full size, I think, will always be king. However, when I want total silence and portability there is no beating iems for sound and ease of use.
