headwhacker
- Sep 4, 2013
Is it possible to connect an iPod classic to input data to the mojo?
No
Thanks to Mojo...
I listened to all of Funky Tonk off the Live Evil Miles Davis album today.
Completely mesmerised. Finally it made sense!!
Probably the first time Ive actually listened to it from start to finish!
All it is good for is color the signal from the mojo. It can't function as an amplifier because Mojo may have a higher output than the B1 due to it's high output impedance. Worse is you may end up with clipped signal given it's lowest gain is at 5dB.
Which should be the Output format in Windows Configuration? I assume I have to manually select he highest 786kHz sample rate but 24 or 32??
Many posters have commented on how smooth and musical sounding Mojo is - and its in part down to the absence of measurable noise floor modulation. Actually getting this performance is very complicated, as within the DAC there are a enormous number of mechanisms to create noise floor modulation. One reason why its taken me 20 years of DAC development to do it!
Rob
Does the sound quality get affected when you use both headphone outs at the same time?
Hi all! Thanks a lot for your comment!I'm so returning it haha
1) Would anyone recommend any extra amp than B1 (obviously not this one!) to drive hd800, e.g., cypher labs piccolo?! Or no need at all?! (I've read some threads people saying they have extra amps for mojo)
2) Any recommendation on portable headphone that would pair up nicely with mojo for classical music? (Mostly orchestra/ chamber music)
I can't carry around hd800 with me on biz trip and etc. so any headphones ranged from 400$ ~ 600$ would be nice to have for mobility!
Thanks again to all!
Yo Chordbros! How do I get line out from the Mojo? Do I just use a 3.5 and the headphone out, plus set do the hold two buttons rainbow thing? Is it true line out, do I bypass the Mojos amp that way, or does it only set the volume to max?
That sets the Mojo to output 3v. You can click down 3 times from there to get ~2.1v if that works better as a source voltage. The Mojo does. To have a separate amp stage - the amplification is part of the DAC audio output. An unusual but much simpler design that other DAC/amps and with, IMO, excellent results.
Why do you want to go Mojo -> Cayin C5 @Marat Sar?
