WCDchee
- Oct 5, 2013
Hey guys, I have the question in to Rob about what new battery tech is in the MoJo. I see they are using Lithium-Polymer (Li-Po) instead of Lithium-ion. This would explain a lot as Li-Po has more storage density and is capable of more raw current output rate (C) than Li-ion, but has usually been more finicky on the safety side of usage. I'm guessing the new battery tech is in the temperature handling as Li-Po has been notorious for not reacting well to heat (experience with high end radio controlled cars and helicopter kits).
I'll let you guys know when I find out more.
Unless I'm mistaken, LiPo is simply a type of lithium ion battery if I remember correctly it is the most commonly used type of lithium ion battery
