Wyd4
it was the longest 10 hours ever.
But worth it
But worth it
But worth it
yep, works great, just waiting on a syscocepts custom optical cable, should have it in the next day or two. I love the PAW5k as a transport and it matches fairly well size wise. It does have a limit of 24/96 if that bothers you.
I have just got a pair of JBL LSR305 monitor speakers to go with my Mojo, is it best to set the volume on the speakers to max and control the volume via the Mojo or put the Mojo into line out mode and use the speaker volume?
Any help appreciated!
Remember that line level output on the Mojo is just a shortcut to 3V. It's the same output source whether you have double red volume lights or double blue volume lights. The only difference is the voltage output level as you are not bypassing a seperate amp in the Mojo (there is none - it's direct from the DACs analogue stage). That said it would probably be best for the speaker to be what adjusts the volume and set the Mojo to line level output. If the speaker amp can't handle a 3V input (you may hear distortion) just lower the volume (voltage output) on the Mojo.
true enough. I don't get distortion when feeding my Audioengines, but it REALLY comes on loud. Not much adjustment via the speakers before it's maxed out! At line-out that is. But the sound is good!
Yeah, for sure! 3V is actually pretty hot as 2V is the standard for CD players and most line out implementations. The point is, turning down the volume on Mojo doesn't take it out of the 'line out mode', except for reducing the voltage level output. It will remain just as clean a signal.
my thoughts too. 3v is "hot" like you say. Wonder why they didn't got for 2v. And yep, the line out mode is more of an "instant max vol" option
