Good day to everyone.
Last day i changed the battery of the Mojo i have, and wanted to post as might be helpful to someone who wants to change the battery as well.
I ordered this battery from Ali Express:
https://de.aliexpress.com/item/1005001594239756.html - it is around 20-25 euro with the delivery, depends on where you are meybe, but should not be more than that.
I do not take responsibility for if you brake your device or get some sort of unusual behavior once you change it. So, if you are not sure you can change the battery, then probably best do not try, or just order it and then give it someone to change it that you are sure can do it.
It has lower capacity than the original one, but whoever gets less than 7 or 6 hours battery life from Mojo might consider changing the battery.
I attach photos with both the original battery seen (whoever wants to try search for original one may see the part number and the specs then) and this one above from Ali Express. Can click on the image to zoom and see it better.
What you need to do is open the Mojo by unscrewing all the screws, pull out the old battery, and very important, be very careful pulling it out, you don't want to damage the port where the battery is plugged in or any other components. The battery will also be glued to the top, so you need to find something to put under it and carefully take it out (the blue thing i used is on the photo). When you get the old battery out, you need something to hold the new one in place, as the glue will be damaged once you remove the old battery. I used insulating tape to hold it in place, which is not the best the way to do it, use few drops glue if you have, i didn't have and this is why used the black tape (not sure how you say it exactly in english, but you can see what it is on the photos), isolierband :
Here i show you that is working:
I will check later how is the battery life compared with the original one when the Mojo is new and will post the results. Meybe somebody will be interested in this, as is cheaper overall than searching for original battery.
And like said above, be careful how you use the Mojo after, don't leave it working without you being around, and don't leave it charging while you are away as well. I do not know if this battery has overtemperature or overvoltage protection, so keep in mind. It says it has, but... Don't leave the Mojo working with it while you are away. If you use it as desktop DAC as well. Use it with you being around. At least this is my advice.
