miketlse
- May 8, 2016
[edited to add links]I mentioned that only because, I know this happens with integrated home audio amps. i had fixed similar (not exact but poor bass timing , dull sounds) on old amps by changing caps. The power caps store the current, and release it according to signal comes in. If they are not behaving correct, then there can be too much wrong with sound. I am not sure if this is how it's implemented in mojo. For instance the hifimes some dac amps had no caps this way which means this issue can never happen. I really wish this is not what is happening with my mojo. I will try contacting chord. Hope they have service like jds ( they were extremely good ppl who walked me through a cap issue, after the warranty was over on my c5d) mojo is still in warranty .
The output stage of the Mojo is virtually direct from the fpga, so only one capacitor to fail.
https://www.head-fi.org/threads/cho...n-3rd-post-◄★☆.784602/page-1092#post-12519944
https://www.head-fi.org/threads/cho...n-3rd-post-◄★☆.784602/page-2203#post-13604597
Contact support@chordelectronics.co.uk if you need to ask for advice about how to proceed.
