GreenBow
- Feb 6, 2015
I just ordered the NH because I hope to get more dynamics from the Mojo than with the actually Hd650...
I also use the Mojo in the desktop setup and I blame it only for the roll off highs. Do you notice that?
I hope you find what you are looking for. All I know is that folk have said a lot, that the Nighthawks are a good match with the Mojo.
Personally I looked at the review of the Nighthawks and thought, probably not for me.
I don't know your price range, but my advice would be read all the reviews you can. Always aim for neutrality and balance between bass and treble. It makes pairing easier. If you can't find what you're looking for, wait. Wait until a manufacturer makes what you want. However, that's not always possible so you have to compromise, but compromise as little as possible. I think that, otherwise I can end up buying twice.
Like right now I am looking for some headphones. They are not at the top of my priorities. Maybe speaker cable comes first, but my Chord Clearway can do its job for some time. I need a portable option, and I am exploring the Poly Mojo. However I have heard that the Mojo will cut off the first half second of music, stored on the SD card. ............. Anyway long story short, I need some portable headphones or IEMs, and eventually some home headphones. If I were to get home-headphones, I would be looking at Beyerdynamic Amiron, T1 2nd Gen, or possibly Senneheiser HD800s. However all three of these headphones choices, makes me think carefully and twice. It's very hard work getting clear about what you want. Yet aiming for neutrality makes it all little surer, if you can find it.
I really wish you the best of luck. If in the end somehow you let the Mojo go, then you know you did the right thing for you. I would not personally be too concerned about the slightly warm tuning of the Chord Mojo. I find the top end has easily enough beauty to be over-sufficient at this price point. ...... To put a little perspective on it. I bought the Hugo 2 two days ago. Down to circumstances, I ended up using the Mojo now and again in those two days. Every time I listen to I still adore it, it still blows my mind, and it's still stunning. ... I would not part with it for love or money.
