What cable do i need so that I can stack the chord mojo with the sony NW-A35?
You should use one of these
WMC-NWH10
Hi all.
I am trying to get a bit more info for current iOS users experiencing a few audio drop outs with the iPhone. Could anyone possibly test this please? Put your phone into airplane mode then reboot? Would like to check if it still occurs ty.
can anyone recommend a USB C to micro OTG cable for use with Cayin N3 to Mojo, I have had a look in the 3rd post but they all seem to be B to micro? Id prefer very short 10cm or so and ideally silver. I have asked pennon already but they don't do one.
oh right ok, I might start looking. I already have the short cable with an adapter but it cuts out with the slightest movement. Thanks
The shortest USB C to Micro USB cable that I've come across, is this one - http://ultimumvitae.com/Details/B01AHQQGUE/HomeSpot-8-20cm-USB-31-Short-Type-C-Cable-Type-C-Male-to-Micro-USB-Male-USB-20-Reversible-Hi-Speed-f
EDIT: It's also on Amazon - https://smile.amazon.com/Adapter-HomeSpot-MacBook-Chromebook-Oneplus/dp/B01AHQQGUE
thanks picked up the 4" from ebay. I like the forza cable but quite expensive.
Yea quite expensive. That's why I went through the cheaper cables first
