http://forzaaudioworks.com/en/product.php?id_product=98 I bought this one, it looks and sounds excellent! However I'm not a cable builder well worth it in my opinion, got the eBay one as a spare tho
The shanling one doesn't work as otg tho which doesn't really make a lot of sense
Bump. I'm about to order Fiio's L19 (lightning to micro USB) that has traditionally worked for users. But with the recent updates, I don't want to waste $30.
I'm sure those boutique cables are amazing! I actually do not like the "cheap" ones off eBay either. So... if you can "tinker" and DIY your own, you'll get a good return on time/money invested. Though, it isn't for everyone.
That cable is an OTG cable (both ends), so I can reconfigure in any way that suits me. It was built out of spare Mogami W2893 that I had lying around.
I'm a DIY guy... I can build a Toxic Cables Silver cabled version for much, much cheaper. I actually built my Coax cable out of Toxic Cables SPC. Works fine.
I wasn't aware that USB-C also required OTG capability. I thought it was supposed to be built into the host device. I will have to continue looking to make sure (or sacrifice one of my cables to verify).
can anyone recommend a USB C to micro OTG cable for use with Cayin N3 to Mojo, I have had a look in the 3rd post but they all seem to be B to micro? Id prefer very short 10cm or so and ideally silver. I have asked pennon already but they don't do one.
