Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. SunVillage
    MYSTERY SOLVED!
  2. TG04
    slight change, but interesting --- hmm, what does it portend?
  3. jwbrent
    Thank you for your reply.
    I was listening last night to Glenn Hansard's album, Rhythm and Repose, the MQA version (TIDAL really needs to add a directory for MQA albums as well as an easy way to identify them in a listing), and as soon as it began I could tell how much better the upper frequencies sounded; it's more noticeable, in my opinion, than the difference between Redbook and Hi Rez in most cases. My plan is to buy a Hugo 2, but the notion of an add-on, although an excellent idea, doesn't appeal to my simplicity sensibilities.
    I do wonder, since Chord uses proprietary DAC technology, whether intellectual property is an issue for them in adoption. I'm not clear what MQA requires of the manufacturer in regards to DAC technology.
    jamestux likes this.
  4. jwbrent
    I'm sure this enabled Chord to save money in manufacturing, not a bad thing at all as long as the design is not compromised.
  5. Mojo ideas
    No they are programmed by a tiny bed of nails connector these are sprung brass and gold contact points aligned and held in place by a small clamp it's all a very normal procedure
  6. jwbrent
    Hey Grumpy, can you confirm whether the nature of balanced drive inherently doubles the impedance spec of any IEM/headphone connected to it?
  7. GRUMPYOLDGUY
    I don't understand the question.
  8. jwbrent
    I'll pm you ...
  9. Rob Watts
    For me there is no issue in my readiness to acquire IP to put into my designs; if I hear a technology that genuinely improves performance and musicality then I would be first in the line to use it, and go to any lengths to get it to perform at it's best.
    Rob
    Chord Electronics Stay updated on Chord Electronics at their sponsor page on Head-Fi.
    https://www.facebook.com/chordelectronics https://twitter.com/chordaudio http://www.chordelectronics.co.uk/
  10. theveterans
    I foresee a poly 2 with built-in MQA to PCM decoder.
  11. jwbrent
    Thanks, Rob, for your reply.
    Will we have to wait for the Mojo 2 to see MQA compatibility or will there be some way to update the existing Mojo?
  12. Rob Watts
    From my post with emphasis:
    if I hear a technology that genuinely improves performance and musicality... "
    Deftone, rwelles, ThomasHK and 4 others like this.
  13. jwbrent
    Understand.
  14. Djsenjaya
    Anyone ever encounter stuttering playback via Dop on uapp Android when playing dsd256? I'm still waiting for the fix
  15. noobandroid
    I'm getting used to the audio delay on win10, no matter what I do, audio delay is there
