Using a coaxial cable, 3.5mm to 3.5mm
Make sure it's 2 pole, Mono, only one black ring on each plug.
JF no scull diggers They were provided with a first sample back in AugustIt is surprising considering that the Mojo was released after the closing of the nominations for the 2015 awards? Maybe they got bored of the current mid level DAC
king, the Arcam IrDac?
How do I connect this thing to my Fiio X3ii and X5?
As the X3ii shares it's coaxial output with the line-out you need to have a 3.5mm four pole TRRS connector on one end for that if you are looking for a custom cable. The X5 requires the 3.5mm 2 pole mono as it has a separate coaxial jack. Basically you need to match up with the adaptors that came with each FiiO unit. The Mojo side is 3.5mm 2 pole mono, like the X5.
http://www.custom-cable.co.uk/custom-cable-cc35-3.5mm-coaxial-cable.html
Hope this might be useful
That is indeed a useful option. Question is, is that at £35 better than the £1.25 (incl postage!) stereo cables available when at such short length?
Such as: http://www.amazon.co.uk/3-5mm-Stereo-Jack-Plug-1-2M/dp/B00077DC3S/ref=sr_1_10?s=electronics&ie=UTF8&qid=1445942804&sr=1-10&keywords=stereo+3.5+to+3.5
Are Chord able to advise on 3.5 to 3.5 cables to the many DAPs that use Co-ax rather than Optical (AKs)? Is mono, and indeed 75ohm, essential for optimum sound quality?
I've always wondered why Fiio never produced a (cheap) short coax-coax for their devices (but they do the L12S wich is the optical one)...An L series cable for around 10 £ would be a great option!
This Fiio 'might' do the job
http://www.hifiheadphones.co.uk/fiio-l8-interconnect-cable-with-angled-jack-7cm-3-5mm-to-3-5mm.html
That's a line out cable. Not the same as coaxial.
EXACTLY correct, I had that happen when I had four devices plugged into my smart charger, and it was only allowing .25a to be drawn by the Mojo, became a solid light as the power freed up, and went up to 1a
how / why would you have the players screen facing the Mojo? Am I missing something pivotal here (ie how to change tracks / albums)?
