Chord Mojo DAC-amp ☆★►FAQ in 3rd post!◄★☆
Discussion in 'Portable Source Gear' started by Mython, Oct 14, 2015.
  1. Light - Man
    Buying second hand, I wonder if the warranty is transferable?
    But I would want to give it a good wash to remove all signs of other peoples grubby paws.
    But perhaps not quite like this! [​IMG]
  2. RPB65
    Canali, I am using this cable at the moment. Only had it a few days but so far it is working well. No connection issues, can bend it enough to put Mojo behind phone, etc.
    Sounds good to me and very small as compared to CCK, etc.
    I too am interested in the new Mojo modules, however am not sure I will bother now if this lead stays as good as it has so far.
    Bought from Lavricables on eBay.
  3. audi0nick128
    Hey there,
    Don't want to start an argument, but I wanted to report back after testing the jitterbug on my Odroid C1+ and I have to say this time the improvements are real (used on the smartphone the improvement I heard were placebo, after all) even though it's not day and night.
    Especially when music playing from my Riva Turbo x, the Soundstage improved noticeably, which also results in better separation of individual instruments...so I am happy with my 50 bug plastic piece :)
    Since we are at it, did anyone try the Klipsch RP 160M driven by MOJO only?
    Cheers
    Traveller likes this.
  4. rkt31
    I am not having mojo and Hugo with me right now. so I was looking for something which could get me me close to mojo/Hugo sound without spending much. I tried Hq player on my laptop and upsampled to 192 khz for CD quality files using sinc filter. sound even from laptop was much cleaner this way but yes not exactly like Hugo or mojo but much much improved as compared to laptop sound without upsampling. I wonder has anybody fed upsampled output to mojo via hqplayer ?
  5. GreenBow
    Probably the best of the rest is an AudioQuest DragonFly version; (Red or black; I dunno).
  6. canali
    DF red is a great little unit (I have both)
    and this Opus # 11 portable dac/amp/battery was just reviewed by Hawaiiboy with high praise.
    (and he's had the mojo, iFi micro and other similar products...he touches upon them comparatively in this review)
    ..anyone else check it out?
    https://www.youtube.com/watch?v=VWlbReetZb8&ab_channel=TheBestBassHeadphonesare...
  7. kinetic758
    After research upon more research, it seems that my combination of Phone (Galaxy S6) and music source (Spotify Offline) my not play well with the Mojo. Is this true? And if so, would using the Mojo strictly as an amp give any noticeable improvement over just the phone? I do intend to make use of the DAC but I haven't yet decided which direction to go with that (e.g. Switching to Tidal and using a custom player or moving to iOS or both).
  8. jamato8 Contributor
    You can't use the Mojo as an amp only. The dac is integrated with the amp so you have to have a digital signal feeding the Mojo for it to work.
  9. discord76
    Does it work well feeding straight into a power amp?
  10. Mython Contributor
    Yes, Mojo works fine, feeding a power amp, from the 3.5mm jack.
    Read post #3 for more information on how to set Mojo to the correct line-out level.
  11. kinetic758
    Gotcha. May have to re-think my setup then.
  12. miketlse
    I sometimes (including today) feed the output from my Mojo, into the AV input on my Arcam Solo neo, and use that to drive my speakers at home.
    This works perfectly well without any problems - but I will warn that upgraditis may make you start wondering if the mojo deserves a better amp for your next birthday or christmas. [​IMG]
  13. Mython Contributor
    I haven't personally tried a Galaxy S6 with Mojo - I'm not certain if the S6 supports USB OTG.
    According to the UAPP homepage, the S6 Edge does, but the S6 is unconfirmed, in their compatibility table.
    There is some mention of it, earlier in this thread, which looks positive, but I don't know if it will run UAPP, and if it refuses to run UAPP, then the Android ROM will forcibly upsample everything to 24/192, which is definitely not the way to get the best SQ from Mojo
  14. xeroian
    I have been testing Mojo and Hugo against iOS 10 beta builds on my iPhone 6s Plus as they have been released. With the iOS release getting close I am now seriously worried. I posted a while ago in the Hugo forum that after a while my music slowed down significantly and a chattering sound was overlaid on the music. With the latest beta my Mojo is also showing the same symptom. This happens with the iTunes music app, Tidal, FLAC player etc.
    I have no such problems if instead I use my iPod 6 which is on iOS 9.3.4.
    Can anyone else confirm problems with iOS 10 public betas or am I on my own here?
    Ian
  15. kinetic758
    Thanks for this. I do believe the S6 supports OTG. My issue is that my music comes from Spotify which I've read doesn't always play nicely with external DAC's. I suppose one solution would be to move to Tidal streaming which I believe is supported by third party player apps.
