rkt31
- Oct 14, 2014
@Traveller, install asio plugin foobar, select chord asio driver as output and you are ready for bit perfect output ( need to disable replay gain too in foobar ) . now you can disable all sound devices in sound mixer. even if you don't disable there will not be any change in volume by any volume slider in sound mixer. similarly chord asio can be selected as output in j river . asio4all won't disable volume control in sound mixer as far as I know. chord's own asio driver is the part of the mojo Windows driver which automatically installs both chord asio and mojo as a device in your pc. these asio drivers are dedicated drivers and do much more than you can think. these allow to send to mojo the maximum bit depth supported ( or even maximum sample rate to in hqplayer ) , establish asynchronous connection , bypass all windows processes etc. for music I have never used wasapi . for movies in vlc player there is no asio support. jriver allows even for movies asio as output.
