Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
- Thread starter Mython
- Feb 11, 2008
The differences you describe are likely down to no noise floor modulation and MUCH more computational power in the Mojo. If you want to understand what Rob Watts has done with the Mojo compared to conventional chips like the one found in the iDSD I highly recommend you read the informative posts section, among others, made by Rob Watts in the third post of this thread.
The reduction of noise floor modulation is directly related to perceived depth in the recording, as Rob has discovered in his many listening tests, which is actually very hard to achieve. Off the shelf chips usually exaggerate the details while the Mojo is smooth, yet Mojo presents the same amount of detail, but more layered, more natural to life, not like everything is heard on one plane. This helps our auditory brain make more sense from what it's hearing and it just feels right.
To your point of the drive ability of IEMs to full sized cans the Mojo has the same power as the Hugo and drives both IEMs and headphones very well. Chord had a new battery developed for the Mojo for thermals and power density to achieve these results in the size of the Mojo.
I got my Mojo yesterday, and have been comparing to my iDSD micro. I hear what people refer as "musical" and "emotional," but I want to understand why. The iDSD sound more flat, more monotone almost compare to the Mojo. Is the Mojo more true to the original sound? I'm not sure, but it sure sounds more fun. It's almost like describing a picture, the Mojo has more contrast and vibrancy, where as the iDSD has a more flatter, but possibly more true color.
Then there's the matter of warmth. The iDSD is known for its warmth, yet that warmth has a bit of way veiling the sound. Mojo also has a hint of warmth, but that warmth is applied without extra veil. I'm in no way dismissing the iDSD, as it is absolutely superb, and perhaps more neutral. But the Mojo just sounds more exciting than the iDSD. I'm comparing using both my HD800 and the Mainline as amp, as well as my SE846 directly plugged into the Mojo/iDSD unit.
One thing for sure though, the Mojo is much more compact and portable than the iDSD. Too bad I'm not using them as portables and strictly as desktop DAC's. The iDSD is more desktop friendly and allows easier charging while being used. I haven't tried both charging the Mojo while it's being used, but I read that it uses battery faster than being charged, being in the desktop mode. Since it has more settings, the iDSD is also more compatible with a wider range of headgear, be it IEM or high impedance full sized headphones. I just love the build on the Mojo though, it's truly a work of art.
Relating sound quality to technical performance is very complex, and I will try to explain, but I could talk for days about it and completely confuse everybody. But here is a quick answer to your questions.
"I hear what people refer as "musical" and "emotional," but I want to understand why" Musicality and emotional is complex, but in a nutshell its about removing distortions that interfere with the brains ability to understand the music. Conventional DAC's have a number of distortions that make it much harder for the brain to perceive the sound. Now we underestimate what the brain does with hearing, and simply make the assumption that the ears convert sounds into nerve impulses, and that's that job done, the brain simply access's the nerve signals. But that's not what happens - audible reality is an illusion created by the brain, and a considerable amount of brain processing is employed to create that illusion. So for example, you listen to a guitar and a singer for example. The data the ears feed the brain is a jumbled up mess of information, and the brain separates this mess of data into two distinct entities - the guitarist and the singer, and you perceive this as two separate entities. Not only that, but the brain very cleverly calculates where in space those entities are, and it does this from subtle timing, amplitude and resonance cues from both ears. But this requires considerable calculation. Moreover, small and subtle distortions (by saying distortion I mean anything that changes the original signal in any non linear way) interferes with the brains ability to separate sounds out into distinct entities, and interferes with the brains ability to place entities in space. This has two consequences for being able to enjoy music - firstly the brain is struggling to process the data, so has to work harder - which means you get listening fatigue, and so you can't enjoy the music. Secondly, being able to enjoy the music means being able to perceive what is going on - and there are many distortions that disable the brains ability to perceive the music. This is where it gets complex, as there are a myriad of different distortions that upset the brains processing. That's why Mojo has the WTA processing, why it filters and over-samples at 2048 times, why its got noise shapers that are a thousand times more resolving than conventional noise shapers - I could go on.
"The iDSD sound more flat, more monotone almost compare to the Mojo" The perception of depth information is down to very small amplitude differences of small signals. Now the brain calculates depth from a number of different cues, but most of it comes from the reverberant sound from the acoustic the recording was made in (or depth is added by adding artificial reverb). Now reverb is very small signals, and the amplitude accuracy of these small signals is crucial for the brain's ability to calculate depth. Now there is something very strange about depth perception - and that is the brain needs these small signals to have perfect amplitude linearity. If a small signal is slightly larger or slightly smaller than it should be, then the brain gets confused and can't calculate the depth properly, and things then sound flat. But the amazing thing is, there appears no limit to how accurate these small signals need to be in order for the brain to not truncate or flatten depth. In order to accurately reproduce depth you need extreme small signal linearity. You can't do this with R2R DAC's, as the resistors can't be matched. With DSD or delta sigma (Mojo is delta sigma too) the problem is now how well the noise shaper functions. As a signal gets closer to the noise shaper noise floor, the levels get smaller, as a signal that is smaller than the resolution limit of the noise shaper is truncated. To overcome this you need to have very high resolution outputs, with a noise shaper that has very high resolution - in Mojo's case, the noise shaper has a thousand times more resolving power than conventional high end noise shapers, and ten thousand times more resolution than DSD 64. But there is another source of error that can upset sound-stage depth and this is digital noise adding to the analogue signal. This applies to all DAC's, and is a big problem with chip DAC's, as there always exists a path from the digital noisy part to the analogue part, and this noise corruption will degrade the small signal non-linearity. But with Mojo the actual analogue parts are discrete, so its possible to eliminate digital noise from corrupting the signal. There is another mechanism for depth to be truncated, and this is with metal to metal interfaces. When you have a soldered joint, or any metal to metal interface, oxides and impurities concentrate at the interface. This oxide barrier is non-linear in that the resistance to small signals is larger than with big signals - so again we have small signals being attenuated. To reduce this problem you can only do this by reducing the number of passive components in the signal path. Conventional DAC's (delta sigma and R2R) have very complex analogue components, due to the need to convert from differential to single ended and to filter the high amounts of RF that comes out of a conventional DAC. With pulse array (my DAC technology within Mojo) this is not an issue as I can get single ended to work, and it runs at 104MHz, so little analogue filtering is required.
"The iDSD sound more flat, more monotone almost compare to the Mojo" I think here you are referring to timbre - the tonal colour of the instrument. Now timbre is an issue with timing reconstruction, as the brain uses transient information to infer the timbre of an instrument. Now conventional digital has uncertainty in the timing of transients (does a signal cross through zero just after a sample, or in the middle or close to the end of a sample?) and the only way of recovering the timing information perfectly is to use an infinite amount of processing on the interpolation filter. With the use of the WTA filter, which has been optimised to recover timing, and 500 times more processing than conventional DAC's, I can reduce the timing uncertainty - which results in much better timbre variation, so things don't sound monotone. There is another aspect in that noise floor modulation also affects timbre reproduction, but this is answered in your next question.
"Then there's the matter of warmth. The iDSD is known for its warmth, yet that warmth has a bit of way veiling the sound. Mojo also has a hint of warmth, but that warmth is applied without extra veil. I'm in no way dismissing the iDSD, as it is absolutely superb, and perhaps more neutral" Warmth or smoothness can be can be artificially created - for example with a dollop of 2nd harmonic. Mojo has very low levels of distortion, so its warmth is not down to doing this or other things. The key to true refinement with DAC's is noise floor modulation. This is where the noise pumps up and down with the signal, and all other non Chord DAC's have large amounts of noise floor modulation. Now noise floor modulation is a scary issue with DAC's, and there are countless ways that a DAC can suffer. Mojo, on the other hand has zero measurable noise floor modulation - the noise floor is at -170dB and it maintains this whether its output is 2.5v or zero, the noise is completely static. Now the issue of neutrality is a very complex thing, as increasing transparency will make it brighter and sharper, and increasing refinement will make it smoother and darker, and its possible to use distortion to create the impression of warmth or brightness. To be honest, I (or anybody else for that matter) do not know what the tonal balance of a perfect (and hence neutral) DAC is. And neutral cam mean different things to different people and with different gear!
Mojo's musical performance is down to lots of technical things - way to complex to talk in detail with - but there are solid reasons why you hear what you hear, and why other DAC's can't do this.
Rob
Amazing replies gents, good source of info right there!
These videos with Rob Watts and John Franks are also informative:
Chord Mojo : How It Delivers Studio Quality Audio From Your Smartphone (seminar by Rob Watts)
Chord Mojo : Smartphones Deserve Better Audio (seminar by John Franks)
Munkonggadgets interview with John Franks, of Chord Electronics
Wreckgar7
- Mar 12, 2016
I need some help, ive downloaded tidal and uapp, and if i understand it correctly, There should be a tidal mode inside uapp settings? I dont see that anywhere.... (i have the paid version)
- Apr 18, 2016
Wreckgar7
- Mar 12, 2016
Is that in usb audio player PRO? Cuz i dont have that says "ACCOUNT"? I just have 3 dots in the right corner, where i can choose settings and EQ etc...
Mojo ideas
Member of the Trade: Chord Electronics
- Oct 20, 2015
I'm concerned that the posting purporting to be from Rob Watts appears not to be solely by him. T I think it sounds to me possibly that a second language English speaker may have added a few lines into the bulk of Robs posting. It could be just a compiling error or that I'm mistaken and ofcourse but it's not like Rob to mention a competitor ever.Amazing replies gents, good source of info right there!
I've been listening to the Mojo a little bit more last night, pairing with the Mainline and the HD800. Even without EQ, it has changed the sound of HD800 significantly. It almost sounds like there's an internal EQ or something, but the top end is definitely smoother and the bottom end is stronger, all while making the mids beautiful. There's almost no need to EQ anymore to boost up the lows and tone down the highs. However, I would still like the option of playing around with my Equalizer APO. Is there a way to make it work with Mojo, or another EQ program that is compatible?
- Apr 18, 2016
Yes this is in usb audio player pro. You need to enter your credentials in order for the application to load tidal playlists and tracks.
Wreckgar7
- Mar 12, 2016
Aha, found it, thanks alot
- Apr 18, 2016
Hmmm. Why don't you call Rob on the phone and ask him if it was really him that mentioned a competitor. I'm assuming you have him on speed dial
- Feb 11, 2008
pending...
warrior1975
- Dec 5, 2013
Seems to have no RF/EMI blocking capabilities. I'm currently im the market for a good microb to microb cable for my S7 edge as well-with built in and end to end EMI/RF shielding. I would think this would be the main selling point of a cable like this, who cares if the highs are better when you hear beep pop fizzle and crack all day. If anyone knows any cables that actually stop or nearly completely mute EMI/FR and are microb to microb, I would like to know. I'm currently attaching several ferrites but would prefer a more elegant and packable sheathed cable.
I just purchased the S7 Edge the other day, I have that same exact cable. I used it briefly earlier, didn't hear any interference but I'll test further when I return to my office if you are still looking.
shultzee
Hello, I was thinking of getting Mojo as a main DAC for my system and HP amp for my HD 650s, do you think it is a good idea?
When using as a main DAC I would connect it to my amp...do I need a 3,5mm mini jack to RCA adaptor for this purpose? At the moment I'm using a Xonar Essence ST connected to my amp using a Wireworld Oasis 6 interconnect... I was also wondering if it is a good upgrade to Essence ST getting the Mojo... can someone explain me how to use it as a main DAC connected to an integrated amp (NAD C326)? In this case is it better to connect it to the Essence ST via SPDIF or to the PC via USB?
Thanks
This one sounds great.
https://www.amazon.com/Audioquest-1-0M-Evergreen-Audio-Interconnect/dp/B00EJNRPBQ/ref=sr_1_fkmr0_4?ie=UTF8&qid=1466032818&sr=8-4-fkmr0&keywords=3.5+to+orca+audioquest
keeya
I have a problem.... The sound cuts in and out (similar to a skipping CD) when streaming from Spotify. But works fine when listening to FLAC files, Bandcamp, etc..
Any ideas?
It's not my internet connection because Spotify works fine if i plug headphones directly into the computer or if i use Airplay to my receiver, it's only when i plug in the Mojo.
Any ideas?
shultzee
Any ideas?
I don't think its a issue directly with spotify>mojo . I stream spotify through the mojo with no issues every day.
keeya
It only cuts in and out when using the Mojo, if i play audio ANY other way (wired directly to headphones, Bluetooth to headphones, wifi to receiver.. ) there is zero skipping.
I can reproduce it instantly by playing through the Mojo.
