Chord Mojo(1) DAC-amp ☆★►FAQ in 3rd post!◄★☆
Jun 15, 2016 at 2:11 AM Post #18,706 of 42,916
Bluetooth module that used aptx or better would be very nice using optical.  I would buy it.
Hell yes. But I imagine this would be a pricey piece of kit in addition to the module and require it's own battery no?
Problem is (for iPhone users at least) that iPhone doesn't yet support aptx. Maybe the next one will if it loses the analogue jack.
For those not familiar with aptx Bluetooth, what sort of audio resolution is it capable of?
Jun 15, 2016 at 2:36 AM Post #18,708 of 42,916
But the amazing thing is, there appears no limit to how accurate these small signals need to be in order for the brain to not truncate or flatten depth. In order to accurately reproduce depth you need extreme small signal linearity. You can't do this with R2R DAC's, as the resistors can't be matched. With DSD or delta sigma (Mojo is delta sigma too) the problem is now how well the noise shaper functions. As a signal gets closer to the noise shaper noise floor, the levels get smaller, as a signal that is smaller than the resolution limit of the noise shaper is truncated. To overcome this you need to have very high resolution outputs, with a noise shaper that has very high resolution - in Mojo's case, the noise shaper has a thousand times more resolving power than conventional high end noise shapers,
You speak as though the Mojo is striving towards a signal target that is 100% correct for real-life soundstaging for the listener, when in fact music is produced for loudspeakers for the most part and the soundstage cues, when reproduced through headphones, are so far off that you're effectively talking about millimetre-precise missile targeting using the Mojo on a targeting system that's using the map of the wrong country for navigation! If the target is off by a thousand miles I don't see how it matters whether you hit the target with nanometre or centimetre accuracy...
No, what you need is a proper HRTF processor that processes the spatial cues encoded in the recording for speaker setups into something that is recognizable by the brain after it is "reproduced" by headphones such that
1. Proper timing and frequency amplitude relationships are all totally destroyed
2. Proper crossfeed of sound signals between left and right ear is completely missing
Conventional headphone soundstaging is mostly a matter of make-believe unless the above are corrected for...
This processing needs to be tailored for the individual for maximum effect, in which case, you can close your eyes and listening to headphones would simply be indistinguishable from listening to the speaker system.
Jun 15, 2016 at 2:47 AM Post #18,709 of 42,916
Hahaha. Now I won't refer to it as anything but the butt plate either.
Wonderful contribution!
well i guess butt plate beats ...  butt plug
Jun 15, 2016 at 3:39 AM Post #18,711 of 42,916
2. Proper crossfeed of sound signals between left and right ear is missing
Joe, IIRC Rob has done most of his listening tests when designing his DACs using speakers (I may be wrong of course). You assume that he is talking about a system when in fact he is only talking about the capabilities of his DACs.
Jun 15, 2016 at 3:52 AM Post #18,712 of 42,916
Well, he gave his nanosecond-accuracy soundstage speech in response to someone listening with headphones and IEMs, so my comment stands.
Edit: Detail-wise, I find that tuning a pair of headphones so that the frequency response flattens out, both in terms of rough bass-mid-treble balance and in terms of removing the sharp resonant peaks that are endemic with earphones at high frequencies, removes masking caused by gross frequency emphases in the case of the former and a sort of comb-filtering effect caused by the latter. As a result the music snaps into focus in a way that is akin to getting glasses for the first time after a lifetime with heavy shortsightness and being used to squinting as a way of seeing more clearly. :p You guys should try it sometime :p
Jun 15, 2016 at 5:31 AM Post #18,714 of 42,916
Basically, they make their DAC circuit, in contrast to most DACs out there (or all other portable DACs and DAPs for that matter) which simply use ready-made DAC chips and put on a nice coating. There is only one other DAC designer that does the same, and that DAC is like over US$100,000.
Jun 15, 2016 at 6:58 AM Post #18,715 of 42,916
Hello, I was thinking of getting Mojo as a main DAC for my system and HP amp for my HD 650s, do you think it is a good idea?
When using as a main DAC I would connect it to my amp...do I need a 3,5mm mini jack to RCA adaptor for this purpose? At the moment I'm using a Xonar Essence ST connected to my amp using a Wireworld Oasis 6 interconnect... I was also wondering if it is a good upgrade to Essence ST getting the Mojo... can someone explain me how to use it as a main DAC connected to an integrated amp (NAD C326)? In this case is it better to connect it to the Essence ST via SPDIF or to the PC via USB?
Thanks
Jun 15, 2016 at 7:07 AM Post #18,716 of 42,916
Thanks
I think Hugo has RCA out but you need to be aware that the connectors are quite tight, therefore you probably can't use RCA cables with thick plugs.
Jun 15, 2016 at 7:24 AM Post #18,717 of 42,916
Well, Hugo is a bit too much for my pockets atm that's why I would choose Mojo... so I was wondering if an adaptor like this or a similar product would be a good choice for my purpose of using it as a main DAC... https://www.amazon.co.uk/AudioQuest-Hard-Mini-3-5mm-Adaptor/dp/B003VJX2F2
Jun 15, 2016 at 7:25 AM Post #18,718 of 42,916
It is true that Mojo uses fundamentally the same technology as Hugo, and is very keenly-priced, considering how much leading-edge DAC technology it incorporates.
Mojo has approximately the same power output as Hugo, and approximately the same complexity of digital processing, but it is tuned slightly differently. Different people will hear the differences differently. Personally, I hear Hugo as sounding slightly more 'airy' than Mojo, but the differences are quite small.
Hugo offers fullsize RCA Phono connections, which Mojo does not. Hugo also offers 1/4" headphone jacks, while Mojo has 3.5mm (1/8") headphone jacks. And there are a few other small differences (Mojo can accept extremely high sampling rates, but almost no one would be able take advantage of that, on the move, due to limitations with portable transport devices currently available).
I'm sure John Franks or Rob Watts will chip-in, if they see-fit, but my understanding, from various interviews I've encountered, is that, following-on from the enormous success of Hugo, the Chord team wanted to get the same fundamental technology and performance into the hands of an even wider audience, and to do that, they had to create something at a much more-accessible price-point. The rationale behind this was (partly) because they wanted to lift more people into the hi-fi realm of portable listening, and thus enjoy their music more than they can from many of the mp3 players and smartphones available in the past few years and present day. Bringing more people into a realisation of how much better music can sound, on the move, when reproduced to a high technical standard, may benefit not only the customer and the company, but, perhaps, by virtue of expanding the industry customer base, the industry as a whole.
I admit some of the above sounds a bit like advertising copy, but it's simply the most succinct way I can relate it to you
You can find the specifications of Hugo and Mojo here
EDIT: mistakenly said Hugo's galvanically-isolated, when it isn't - cheers x RELIC x for the correction!
Jun 15, 2016 at 7:38 AM Post #18,719 of 42,916
Please read the 'Informative posts by Rob Watts' section of post #3. I've included loads of discussion, there, that will help in your understanding.
Hugo offers fullsize RCA Phono connections, which Mojo does not. Hugo also offers 1/4" headphone jacks, while Mojo has 3.5mm (1/8") headphone jacks. Hugo has galvanic isolation, while Mojo does not. And there are a few other small differences (Mojo can accept extremely high sampling rates, but almost no one would be able take advantage of that, on the move, due to limitations with portable transport devices currently available).
Just to clarify, the Hugo does not have galvanic isolation. Only the desktop 2Qute, Hugo TT, and DAVE have it. It draws too much power for portable setups.
Jun 15, 2016 at 7:41 AM Post #18,720 of 42,916
Thanks for correcting me!  I should've taken more time in typing that reply!
I've gone back to correct it, not to hide my mistake, but just to avoid unnecessary confusion - cheers
